question ARP head studs..
Old Mar 26, 2006 | 11:42 AM
NAlover's Avatar
Default question ARP head studs..
since i wanted to build my b16 i bought 6 months ago a set of ARP (B16) head studs. BUT i changed my set up to LSVTEC i wonder if i can still use then... i don't think there is no problem but i just wanna make sure. thanks correct me if i'm wrong
Old Mar 26, 2006 | 11:47 AM
Combustion Contraption's Avatar
B16 has a shorter deck height than the LS blocks. They wont thread in completely. ARP makes studs specifically for the combo youre going to run.
Old Mar 26, 2006 | 01:10 PM
NAlover's Avatar
Default Re: (LsVtec92Hatch)
so they won't work??? if so i would have to trade or sell then..
Old Mar 26, 2006 | 01:14 PM
They will seem fine to the eye im guessing. But i wouldnt risk it.
Old Mar 26, 2006 | 01:29 PM
NAlover's Avatar
so should i buy the b18's studs? i'll be running 12.5:1 CR so i want to keep the head inside the hood.
Old Mar 26, 2006 | 02:27 PM
Edit: My stupidity. The GSR/Type R will work, i used those for my build and a few others. The below poster is correct, i just had a brain fart.
Modified by LsVtec92Hatch at 5:17 PM 3/26/2006
Old Mar 26, 2006 | 03:57 PM
b18bEKcoupe's Avatar
The ls studs will not work for you. The two middle studs will be too long. You will need to get some gsr or type r studs.
Old Mar 26, 2006 | 04:18 PM
Old Mar 26, 2006 | 04:25 PM
enforcer's Avatar
you dont even have to use arp's you can use stock head bolts and you will be fine. with head studs you will have to pull the head back off after running the motor to retouch them. they are hard to get the correct specs on them the fisrt time.
Old Mar 26, 2006 | 06:39 PM
ExospeedAMcrx's Avatar
B16A block + B16A head = B16 head studs(not GSR, not LS)
LS block + GSR head = GSR head studs
LS block + B16A Head = GSR Head studs
B20 block _B16/GSR Head = GSR head studs
SOHC:
D16A6 motor = ARP D16Z6 head stud kit
D16Z6 motor = ARP D16Z6 head stud kit
D16Y8 motor = ARP D16Y8 head stud kit
Old Apr 1, 2006 | 04:54 AM
NAlover's Avatar
Default Re: (exospeedAMcrx)
so i guess i gotta trade the b16's for gsr's. expletive
DC2.KILLA
Apr 16, 2011 06:43 AM
Red D Dragon
Jun 28, 2004 06:34 AM
Turboteggy
Jan 14, 2004 04:17 AM
straightline
Apr 7, 2003 09:42 PM
Mugen Dom
Feb 28, 2002 11:53 AM
