'00 gsr swap into a '95 civic with obd1 gsr ecu...some questions
Old Apr 3, 2002 | 07:21 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default '00 gsr swap into a '95 civic with obd1 gsr ecu...some questions
the engine harness if for the '00 motor and plugs up to the civic main harness. is this the right harness to be using for this swap? and if so, do i just need to run the extra wires and everything will be fine? or is there anything that needs special attention to wire up? i am in the middle of this swap and am trying to get the wiring done today. thanks.
Old Apr 3, 2002 | 08:43 AM
jdmekcivic2eg's Avatar
Default Re: '00 gsr swap into a '95 civic with obd1 gsr ecu...some questions (not so civic)
not sure if this helps but i have a 93 dx with a 97 ls motor everything pluged up fine all i had to use was a 94 ls ecu obd1 you might have to wire up the vtec etc. not sure..
Old Apr 3, 2002 | 10:51 AM
hybridreams's Avatar
Here's a good wiring diagram - check the whole site out as well...
http://hybrid.honda-perf.org/tech/info.html#B18EG6
douglasd07
Jan 14, 2016 06:19 PM
DA STRIKER
Mar 2, 2011 08:48 PM
JOE_DC4ever
Dec 14, 2010 07:12 PM
DFW
Aug 10, 2009 07:02 PM
Vindicator9000
May 3, 2008 05:29 PM
