What am i doing wrong? Launching on Slicks
Old Mar 26, 2006 | 09:27 AM
Quad-Damage's Avatar
Default What am i doing wrong? Launching on Slicks
Setup
255whp Turbo (MIght be 300whp IF I EVER DYNO)
Omni Power Street Setup with upgrade steal collers
Full Race Bar
Hasport Race Mounts
Lenso with 24.5 13 inch slicks (NEW) Hoosiers
Luanching at 6400 i was spining the slicks real bad, after i was done spining it was in 3ed and i boged hella bad, thanks t3/t4 and had to downshift to 2ed gear + Im getting 2.6 60's times on slicks. that was with a 7200 redline (ouch)
now i got a 8200 redline pulls hard all the way till redline
I pull the e brake and did a 2ed gear burnout for a good 10 seconds in the water box as well
I have a higher redline from the last time at the track and like 4 more lb's
What should i be launching at?
Old Mar 26, 2006 | 09:31 AM
ExospeedAMcrx's Avatar
what was the tire pressure on the slicks?
Also, sometimes you just have to adjust your driving style. don't floor the gas all the way, feather it so its not on full throttle and reduces the spin, once it catches, then you gas it until you have to shift.
Old Mar 26, 2006 | 10:39 AM
SiKnezzALLmotor's Avatar
Default Re: What am i doing wrong? Launching on Slicks (Quad-Damage)
yea tire psi makes difference dont worry alex you'll get it down
Old Mar 26, 2006 | 12:47 PM
Default Re: What am i doing wrong? Launching on Slicks (SiKnezzALLmotor)
i started at 14 psi and worked my way down to 10 psi
Old Mar 26, 2006 | 02:49 PM
lower that thing and heat the **** out them hoosier slicks prolly have hard compound
Old Mar 26, 2006 | 02:58 PM
MADPROPS's Avatar
How old are the slicks, I had a similar problems with slicks that were from the year before, not many passes on them they were just not stores over the winter properly
Old Mar 26, 2006 | 03:12 PM
Default Re: What am i doing wrong? Launching on Slicks (MADPROPS)
maby 6 months old i bought them new, i store then inside a airplane hanger storage bin in my backyard, they are sitting sideways
Old Mar 26, 2006 | 05:25 PM
TheWickedOne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">Setup
Full Race Bar
Hasport Race Mounts
What should i be launching at?</TD></TR></TABLE>
"burnout for a good 10 seconds in the water box"
By no means i'm not a pro .. but since i've been racing ..I've never done a burn out in the water box ... What you should do is either do a quick spin in the water box then align the slicks right in front of the waterbox in the "burnout box" then do your burnout. Thats just my 2 cents
Old Mar 26, 2006 | 05:41 PM
Default Re: What am i doing wrong? Launching on Slicks (TheWickedOne)
it's the gap where u can put ur tires inside, is that the burnout box? thats where everyone else did there burnouts, i'm not thinking right
Old Mar 26, 2006 | 05:52 PM
TurboLaxx's Avatar
i think you are supposed to do a quick "spin" in the water box to coat the tire in water. Then you pull up out of the water box and do your full burnout. That's they way i was told to do it.
Old Mar 26, 2006 | 05:57 PM
Default Re: (TurboLaxx)
Quad Here you go ..
Not to scale...
Old Mar 26, 2006 | 05:59 PM
Turbo-charged's Avatar
there has to be a whole lot going wrong on this one. i was getting much better 60 foots than that on my 18" racing hearts with junk street tires.
your def. running way too much air pressure. ive done numerous burn outs in the water, thats not your problem. sounds like you are over doing your burn out as well.
do you have a 2 step? how much boost are you building on it if so? try launching at a lower rpm. if it starts spining real bad left off the throttle a little bit.
i dont really know how to offer much more help on this one. no offense but with a 2.6 60 foot and DOWNSHIFTING going down the track.....im going to go ahead and say you just need some practice?
Old Mar 27, 2006 | 05:16 AM
b18c195's Avatar
Default Re: (TheWickedOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">Quad Here you go ..
Not to scale...
lol
what if your in the right lane what do you do...
Old Mar 27, 2006 | 07:29 AM
1FSTHATCH's Avatar
Default Re: (b18c195)
I set my tire pressure around 7-8 before going into the box, try going to that range...
Old Mar 27, 2006 | 07:41 AM
Default Re: (1FSTHATCH)
will do this saterday
Old Mar 27, 2006 | 07:42 AM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c195 &raquo;</TD></TR><TR><TD CLASS="quote">
lol
what if your in the right lane what do you do...</TD></TR></TABLE>
haha lol...
Old Mar 27, 2006 | 07:25 PM
96 GSR-T's Avatar
Default Re: (gsrious)
I'd say feather the clutch more, **** I had a 1.9 60' on bald azenis's with a blown motor and like 10lb
Old Mar 27, 2006 | 11:10 PM
VRD^don's Avatar
Default Re: (96 GSR-T)
heavy foot????
Old Mar 27, 2006 | 11:47 PM
precisionelite's Avatar
I pull the e brake and did a 2ed gear burnout for a good 10 seconds in the water box as well</TD></TR></TABLE>
What's the point in doing a second gear burnout? Won't that mess up your tranny, why not just use 1rst gear. Isn't it about RPM not MPH?
Old Mar 28, 2006 | 12:00 AM
ImportMotorSpec's Avatar
Default Re: What am i doing wrong? Launching on Slicks (precisionelite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precisionelite &raquo;</TD></TR><TR><TD CLASS="quote">What's the point in doing a second gear burnout? Won't that mess up your tranny, why not just use 1rst gear. Isn't it about RPM not MPH?</TD></TR></TABLE>
It is the speed of the tire that heats it up. The faster, the more friction, kinda like sex...
Old Mar 28, 2006 | 12:09 AM
midnitesol's Avatar
Default Re: What am i doing wrong? Launching on Slicks (ImportMotorSpec)
my advice is launch lower and lower until no wheelspin. if you must rev higher to prevent bogging. never in no means get through third gear without traction and try downshifting.
Old Mar 28, 2006 | 05:22 AM
96 GSR-T's Avatar
Yea thats pretty obvious that the faster it is spinning the faster it heats up and the shorter the burnout has to be
Old Mar 28, 2006 | 07:07 AM
R@mon's Avatar
Default Re: What am i doing wrong? Launching on Slicks (96 GSR-T)
dont just shift the car because the car got to the redline from spinning either back off the throttle slightly to let it build mph or let it ride the limiter till you feel its time to shift it. also like everyone else said use the water box only to wet them then drive up past it about a 2 or 3 feet then do the burn out there.
do you have a lsd?
Old Mar 28, 2006 | 07:17 AM
gitwidit's Avatar
Default Re: What am i doing wrong? Launching on Slicks (R@mon)
Drop tire pressure down to 6psi and launch at 7k.
Old Mar 28, 2006 | 08:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec &raquo;</TD></TR><TR><TD CLASS="quote">
It is the speed of the tire that heats it up. The faster, the more friction, kinda like sex... </TD></TR></TABLE>
What RPM should you let the clutch go in 2nd to get a good burnout. Also should you gradually let the clutch go, or just drop it and go full throttle?
