how to swap your injector plugs (crxsi to gsr ) lots of pics beware...
i hope that this post i made will help some people. i plan on making more step by step posts like this as i do this swap.
titles are on top of the pics that they go to...
this is the gsr injector portion of the harness.
this is the crx injector portion of the harness
cut off the crx plugs and number them just incase. they are number in the way that i took them off (passenger to drivers side) be sure to leave enough wire on the old plugs so they can be used again if necessary.
now cut off the gsr plugs in the same order and strip the wires
now splice them solid wire to solid wire and striped to striped (solids are ground and striped are 12v)
get your solder
solder them up
keep repeating the process
one left to go
the last gsr plug to be cut off
a better pic of the process in the works
all done and soldered up
now put the plugs on the motor so you can better loom and tape so they all reach and come out in the right places.
you may butt splice instead of the way i did it and heat shrink its less bulky afer wrapping
i just think that its a better splice this way and u never see it anyway....
get your solder
solder them up
one left to go
Tinning the wires makes for less buldge in the tape... heatshrink is your friend.
Also, now you need a how to on the inj resistor box end. You have to find a way to merge all the wires together.
Ryan
Ryan
Crx_Civic
Apr 27, 2008 11:41 AM
Tuner Eddy
Aug 2, 2005 04:48 PM
