turbo or all motor
Old Mar 26, 2006 | 07:57 AM
sanman's Avatar
Default turbo or all motor
what up . my name is tony i have 96 integra LS. i have some work done to it alredy. ie, catback, headers, cold air intake, springs, thats about it. i am curious if i am better off putting a bolt on turbo on it or just adding lots of engine mods.
Old Mar 26, 2006 | 08:20 AM
AMLS4dr200whp's Avatar
Default Re: turbo or all motor (sanman)
for the money and power, turbo, if u want to do something different but it will cost alot, all motor
Old Mar 26, 2006 | 08:27 AM
ChicagoMike's Avatar
Slap on a VTEC head and go all motor!
Old Mar 26, 2006 | 08:29 AM
.brian.'s Avatar
Default Re: (RippinVTEC)
you have headers? interesting. i think you mean you have a header.
if you want to net the most HP for the least amount of money, i would go turbo. you have an LS which is a good platform to start for a boosted motor.
if you went all motor, you would have to spend tons more money just to achieve the same amount of power you would from a turbo. the cost/power ratio is just not worth it, IMO.
boost your LS don't forget to get it tuned
Old Mar 26, 2006 | 08:39 AM
JDMilanoRed's Avatar
Default Re: (.brian.)
all-motor is usually pretty pricey... but then again, turbo can be just as pricey!! Turbo gives you more HP for your money, but will be tougher to maintain... also, your LS motor is a good candidate for turbo, rather than N/A
Old Mar 26, 2006 | 08:48 AM
LL2009's Avatar
Default Re: (JDMilanoRed)
Boost that bitch
Old Mar 26, 2006 | 08:57 AM
BMo Tuning's Avatar
STAR
ls engines absolutely love boost, civic around here runs 14psi on his stock LS and runs mid 11s @120mph on slicks!
Old Mar 26, 2006 | 10:53 AM
EF mark's Avatar
but also keep in mind a well tuned turbo motor is just as realiable as the next motor setup all about tuning and safeguarding
Old Mar 26, 2006 | 10:57 AM
dohcMONSTER's Avatar
Default Re: (iheartlittlebear)
N/A=tracks and turns
turbo=straight line
Old Mar 26, 2006 | 11:17 AM
sh!tsWEAK!'s Avatar
Default Re: (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">This question can not be answered properly without us knowing what your intent for the car is, your budget, and your power goal.
All motor is good for track, you won't have traction issues and you can control your power more precisly. Iis easier to have an N/A car for a daily driver then a boosted one. The cost to obtain the same HP as you would with boost, it would be drasticly higher with N/A. But that does not mean that turbo is better.
Boost is good for a drag strip. Keep in mind, generally this will put more stress onto your engine. More frequent oil changes, parts failing, and etc... It can get pretty expensive for maintence. </TD></TR></TABLE>
Couldn't agree more. I traded boost for reliability because I needed a break from all the little problems associated with a boosted cars. But after college and everything is out of the way, I will build a boosted car on the side but keep my GSR n/a so I have a dependable daily driver. I do miss boost a LOT, but priorities come first.
integrals957
May 31, 2006 10:35 AM
allmotorsleepingcivic
May 15, 2006 08:30 PM
greddy13
Jan 27, 2006 02:54 PM
CRX_Type_R
Nov 19, 2004 10:49 PM
silverb18
May 20, 2004 10:49 AM
