OLD BMW wheels clear GSR brakes?
Old Mar 26, 2006 | 06:44 AM
P@@RB@Y's Avatar
Default OLD BMW wheels clear GSR brakes?
There P195/60R14. Will they clear the 3G GSR brakes?
Old Mar 26, 2006 | 07:15 AM
nickG's Avatar
Default Re: OLD BMW wheels clear GSR brakes? (P@@RB@Y)
ive seen a couple ppl w/ them on g2s and the brakes are the same. if they are local, try them on before you buy them..
Old Mar 26, 2006 | 09:18 AM
cm zak's Avatar
I'd like to see how they look once you got em on, post it up
Old Mar 26, 2006 | 09:55 AM
DADADAAAMN's Avatar
what size are they 14's or 15's? if they are 14's, then spacers are ur friends!
Old Mar 26, 2006 | 10:16 AM
CleanLikeJdm's Avatar
Hype-R Stalker
I had some pimpin e21 13's on my back for a temp solution to a tire ticket.
Only thing is the center hole is a little bigger, but if they're off an e30 and have 4 lugs(which if they're e30 they should all be 4lug) they fit fine.
Old Mar 26, 2006 | 10:37 AM
Lauj87's Avatar
should clear...i believe the civic HX rims are 14's..seen couple of those on teggies b4 so you shouldn't have any problems
Old Mar 26, 2006 | 11:00 AM
P@@RB@Y's Avatar
Default Re: (Lauj87)
There off a 318 they said.
I have to drive about an hour and so do they to meet up.$80. for the wheels and decent tread tires.
Old Mar 26, 2006 | 11:29 AM
Hype-R Stalker
Default Re: (P@@RB@Y)
pretty good deal if they have tires, I saw a da somewhere on here with those bottlecaps too.
Old Mar 26, 2006 | 11:31 AM
b20integrapower's Avatar
Default Re: OLD BMW wheels clear GSR brakes? (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">I had some pimpin e21 13's on my back for a temp solution to a tire ticket.
how do you get a tire ticket?
Old Mar 26, 2006 | 02:10 PM
garados's Avatar
Default Re: OLD BMW wheels clear GSR brakes? (b20integrapower)
probably low to no tread. Legal limit is 3/32" or something. Anyways, those wheels will fit. I tried them on my old db8 and they spun just fine without altering the brakes.
Old Mar 26, 2006 | 05:30 PM
Hype-R Stalker
Default Re: OLD BMW wheels clear GSR brakes? (garados)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados &raquo;</TD></TR><TR><TD CLASS="quote">probably low to no tread. Legal limit is 3/32" or something.</TD></TR></TABLE>
Exactly
Old Mar 26, 2006 | 06:52 PM
Rtistik.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">should clear...i believe the civic HX rims are 14's..seen couple of those on teggies b4 so you shouldn't have any problems</TD></TR></TABLE>
the calipers need to be shaved to fit HX's i believe
or run spacers
Old Mar 26, 2006 | 07:42 PM
DADADAAAMN's Avatar
Default Re: (Rtistik.)
exactly. i have hx's on my DA and i have to use spacers on my front brakes. and those are 14's.
Old Mar 26, 2006 | 07:49 PM
hamburgler's Avatar
Default Re: (DADADAAAMN)
those wheels are all over junkyards for the lowlow
phivelug
Feb 16, 2005 07:58 PM
tmalzahn
Feb 14, 2005 06:48 PM
HotHB
Sep 8, 2002 02:27 PM
dom93hatch
Aug 7, 2002 08:08 PM
Calesta
Nov 28, 2001 10:37 AM
