relocating the battery in the trunk... need help
Old Mar 26, 2006 | 05:07 AM
RACEPAK's Avatar
Default relocating the battery in the trunk... need help
anyone have instructions on how to relocate the battery in the trunk?
i made a bracket and i need to wire it.
i did a search and i saw pepole using 4 gauge wires. and a fuse.
i need to know if i need to wire both wires from the front to back of the car? cant i just run one + to the front and to ground the battery somewhere in the trunk?
also... what fues do i need to use?
thanks...
Old Mar 26, 2006 | 05:10 AM
Autoworks's Avatar
Default Re: relocating the battery in the trunk... need help (RACEPAK)
I ran both of mine to the bay and grounded it in the trunk, but you can run 1 to the bay and ground the other in the trunk if you want.
Also, you don't have to use an inline fuse.
Old Mar 26, 2006 | 05:39 AM
SIRIUS's Avatar
Default Re: relocating the battery in the trunk... need help (Autoworks)
Just run the power wire to the back and ground the battery in the rear. Are you using a battery box? If not alot of tracks will ive you ****. Summit, Jegs, etc sells kits that include everything you need to relocate the battery.
Old Mar 26, 2006 | 05:17 PM
RACEPAK's Avatar
Default Re: relocating the battery in the trunk... need help (SIRIUS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">I ran both of mine to the bay and grounded it in the trunk, but you can run 1 to the bay and ground the other in the trunk if you want.
Also, you don't have to use an inline fuse.</TD></TR></TABLE>
lets say i want to use a fuse ..... which one should i use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS &raquo;</TD></TR><TR><TD CLASS="quote">Are you using a battery box? If not alot of tracks will ive you ****. Summit, Jegs, etc sells kits that include everything you need to relocate the battery.</TD></TR></TABLE>
i'm not using a box, ill make one along the way....
besides.... i'm from israel, we dont have any tracks here
Tcoy23
Apr 24, 2014 12:17 AM
f22a1 ftw
Aug 22, 2010 12:43 PM
bdmlilburn
May 16, 2009 12:40 PM
91EF919
Apr 6, 2009 08:27 PM
rdeezy78
Audio / Security / Video
10
Aug 27, 2007 03:16 PM
