wiring help...
Old Mar 26, 2006 | 01:48 AM
the soL that could's Avatar
Default wiring help...
i've searched for 3 days... still don't know what the hell these wires are for and where they pin at on the ECU.
my obd1 swap (SOHC to JDM D15B) had a sensor clip out and no codes. (same one)
i think it's the EVAP purge solenoid wires that were from my USDM d15b7. what pins are those on the ECU?
right now, i have an OBD1 JDM B18C (JDM p72 ecu) and a wire harness off a 94 del sol S. i would like to wire my knock sensor (to one of those wires) and IAB (ground to chassis and wired to the other wire) to that clip that's not in use. but i have no idea where to extract the one with the ? (yellow/black stripe) & (red solid) in the picture on the ECU (pin#) to place into the knock and IAB spots. thanks~!
Modified by the soL that could at 11:24 AM 3/26/2006
Old Mar 26, 2006 | 05:21 AM
civictype-r's Avatar
Default Re: wiring help... (the soL that could)
i have been searching to find out what those wies are for.the wires go to the intake manifold where a vaccum line comes off it and goes the canaster and im trying to find out what to hook them up to.i have a b18c and my vtec isnt working kick on for a second and goes off then motor starts to bogg.i dont know if that clip has anything to do with it.
Old Mar 26, 2006 | 10:27 AM
tallkan
Mar 1, 2009 12:00 PM
toolbox21
May 28, 2008 04:02 PM
B18cFreak
Feb 13, 2008 08:52 AM
the soL that could
Mar 26, 2006 11:39 AM
daver
Sep 19, 2003 04:38 AM
