HELP!!!! Walbro fuel pump install problem!!!
Old Mar 26, 2006 | 12:31 AM
FuNkDrSpOt's Avatar
Default HELP!!!! Walbro fuel pump install problem!!!
I'm in the middle of installing my fuel pump and there is a small metal washer that holds the fuel filter on. The small plastic part that allows the metal washer to connect to the fuel pump snapped off under very small physical pressure.
What do i do to keep the fuel filter on?!
Can i super glue it or ziptie it or what?!
Old Mar 26, 2006 | 12:53 AM
FuNkDrSpOt's Avatar
Default Re: HELP!!!! Walbro fuel pump install problem!!! (FuNkDrSpOt)
ttt, i need some immediate help here
Old Mar 26, 2006 | 01:13 AM
FuNkDrSpOt's Avatar
13 looks and not one poster?
ok, if anyone finds this and knows the answer, please let me know
I'm assuming that hardened superglue wont interact with gasoline since saturated hydrocarbons don't usually chemically interact with anything else.
Old Mar 26, 2006 | 05:29 PM
808_si's Avatar
okay, nevermind. lol.
Old Mar 26, 2006 | 05:31 PM
Sketch_hs's Avatar
how did you break that lol
maybe some jb weld will work? i donno
Old Mar 26, 2006 | 06:53 PM
posite's Avatar
wont hurt to reuse the old one.
Old Mar 27, 2006 | 03:41 AM
mstsh80's Avatar
they are very cheap from a parts house, but dont feel bad i did the same on a gsr.
i used 2 zip ties very securely and make sure it will never fall off. those walboro filter screens are garbage,also make sure you use good quality zip ties due to the fact that they are in gas all the time.if you have time, just get a new one.
Dohc eg coupe
Feb 15, 2015 05:22 PM
enriquev
Oct 11, 2007 05:31 PM
mini-v-si
Jun 1, 2004 03:06 PM
JICsube
Sep 11, 2002 06:38 PM
