replacing manual trans fluid
2 plugs, one on top one on botom. losen one on botom, drain oil. Replace. Losen one on top. fill with oil till full up to the fill plug. Replace. DuN
Use your favorite motor oil.10-40 works for me. OR Honda maual tranny fluid $$$
Kinda blew my mind when I heard you use motor oil in a tranny. I have only built domestics in the past and that is unheard of in that world.
i suggest that you take the top bolt off first and then the bottom. the reason is that I took the bottom one off first and drained the oil but then I couldnt get the top one off because it was stripped...i was pissed. I finally figured out that you can put the oil in through a smaller bolt on top of the tranny but that was a bitch.
lonefuzzy79
Apr 30, 2002 07:51 PM
