car won't start :(
Old Mar 25, 2006 | 10:14 PM
DongTran's Avatar
Default car won't start :(
So here's how it all started. My gf woke me up yesterday said help car won't start! I go downstairs, turn the key, starter clicks. I try the windows, VERY weak. So I hook up a booster, fire it up okay. let it run for a little bit, try starting again, junk. So I'm pretty convinced it's the alternator.
So I swap the alternator, try starting again, kind of a really FAST clicking. I realize that there's still barely any juice in battery, so I hook up booster (yes I hooked it up correctly) and it does the same thing. I tried it like 2x, and for some reason, I decided to turn the key again. Now, dash lights do not come on, and I do not hear the fuel pump, none of the accessories work. Radio works, and the light on climate control works too, though.
Don't ask me why, but I had an extra ignition switch laying around, decided to try that on for size, same results.
I know it's going to be something super stupid, but I'm really stumped right now....
help
Old Mar 25, 2006 | 10:41 PM
Sick Shift's Avatar
Default Re: car won't start :( (DongTran)
slightly helps if you tell us what car it is("prelude" isnt that specific)
have you hooked up an O meter to the battery?
Old Mar 25, 2006 | 11:34 PM
DongTran's Avatar
Default Re: car won't start :( (Sick Shift)
lol forgot to mention, 2000 base poonlude 5spd.
my multimeter was stolen when my toolbox was stolen, so the answer to your question is no. the battery is a 1 year old yellowtop. I have tried jumping it with a spare costco battery I have, as well as charging it w/ no cables connected via my exide charger, jumping it via a charged booster pack i have, no dice.
Old Mar 25, 2006 | 11:38 PM
Shakes's Avatar
space cadet
you swapped batteries already?
Old Mar 26, 2006 | 03:54 AM
reset2k's Avatar
Could be the starter - my sis's 89 civic did the same thing, radio worked, etc.. but all you heard was clicking. I would def say the starter
Old Mar 26, 2006 | 05:34 AM
h23civic's Avatar
try tapping on your starter with a rubber mallet or something else that won't hurt metal, then try and turn the engine over again. if the starter cranks after you tap it you know its going out. does it feel like you still have low battery voltage? windows still move up and down slow, dim lights, etc.
Old Mar 26, 2006 | 05:57 AM
prelude1897's Avatar
Default Re: (h23civic)
change your battery If your car started the first time after jumping it, then that's probably your problem
Old Mar 27, 2006 | 12:14 PM
DongTran's Avatar
switched out the 7-pin main relay, checked fuses, changed battery, still no dash lights in no 2/3 position of key nor does the car start.
Modified by DongTran at 1:27 PM 3/27/2006
c00ker
Honda Civic (2001 - 2005)
Jun 23, 2011 06:45 PM
soto2635
Jan 15, 2009 10:44 AM
wreckedmyteg
Apr 20, 2006 09:23 PM
91sicrxer
17
Jun 15, 2005 08:10 AM
See Are X
Sep 18, 2002 07:48 PM
