Short Shifter- Where to get one. . .-SEARCHED
Old Mar 25, 2006 | 09:03 PM
h22vt's Avatar
Default Short Shifter- Where to get one. . .-SEARCHED
So i ordered one from PSPEC, i havent heard anything from them since i placed my order. If i dont hear something within the next couple days Im going to report them! Anyways, what would you do? who else makes them for a 5th gen?
Old Mar 25, 2006 | 09:10 PM
4bidden's Avatar
Default Re: Short Shifter- Where to get one. . .-SEARCHED (h22vt)
Workin' on mine now. Adjustable for throw (and possibly height), heavy as possible (good), etc.
And NO, I don't know when it will be done
Old Mar 25, 2006 | 09:11 PM
h22vt's Avatar
thats cool, but it doesnt help me at all!! lol!!! ive heard many good things about your 4th gen shifter!! that only means one thing you need to hurry!!!!!!!!!!!!!!!! lol
Thanks
Old Mar 25, 2006 | 09:50 PM
E-Money's Avatar
Default Re: (h22vt)
give it time with Pete (pspec tuning)
Old Mar 25, 2006 | 10:53 PM
95greenlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22vt &raquo;</TD></TR><TR><TD CLASS="quote">So i ordered one from PSPEC, i havent heard anything from them since i placed my order. If i dont hear something within the next couple days Im going to report them! Anyways, what would you do? who else makes them for a 5th gen? </TD></TR></TABLE>
best advice....wait for the 5th gen Forbidden shifter to come out....IT WILL BE THE BEST FOR YOUR CAR....IT IS THE BEST FOR THE 4TH GEN. AND I DONT THINK JEREMY WILL SETTLE FOR ANYTHING LESS THAN TEH BEST!
Old Mar 25, 2006 | 11:13 PM
airmax's Avatar
4bidden.. i like your shifters. but is there any way you think you can cut it down another inch or so to make it shorter... By doing so will it affect it's function in any way? If not, will you be able to cut one down for me to purchase? thanks
Old Mar 25, 2006 | 11:15 PM
Default Re: (pprreelluuddee)
well the 4th gen is a half inch shorter......its not in the shortness of the shifter though.....
Old Mar 25, 2006 | 11:23 PM
airmax's Avatar
yea i know it's a half an inch shorter.. but it still sits so high IMO.. i would just like it to be a bit more shorter.. the throws are fine though, that is what counts right? but i want the stick overall to be just shorter
Old Mar 25, 2006 | 11:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprreelluuddee &raquo;</TD></TR><TR><TD CLASS="quote">yea i know it's a half an inch shorter.. but it still sits so high IMO.. i would just like it to be a bit more shorter.. the throws are fine though, that is what counts right? but i want the stick overall to be just shorter</TD></TR></TABLE>
correct....teh height of the shifter doesnt hane much to do with the overall throw...imo....talk to some road racing guys.....they like shifters that are LONGER than stock...
Old Mar 25, 2006 | 11:30 PM
airmax's Avatar
yea i understand that shorter the throws is not based on how short the shifter is.. i am fully aware of that.. and yea.. i also.. know that ROAD racing or any of those sorts want it LONG because they want to be able to shift quick and keep BOTH hands on the steering wheel.. BUUUUUUT.. i would just like my crap to be SHORTER! haha
I want it short like a civic or an integra that has only about a quarter of an inch and the shift **** visiable
Old Mar 25, 2006 | 11:43 PM
wehhh,,...refer to this if i am confusing j00!!!
w00yt https://honda-tech.com/zerothread?id=1572240
Old Mar 26, 2006 | 06:35 PM
airmax's Avatar
bump for 4bidden to get a chance to read my post!
Old Mar 26, 2006 | 07:14 PM
4bidden's Avatar
You can cut it down however short you would like. You can go down about another 3/4'' as it comes before the shift **** will hit the part of the lever that angles out. If you trim that, you can go farther.
However, I cannot do this for you. I do large runs of the shifters to keep the costs down as much as possible.
Old Mar 26, 2006 | 07:27 PM
airmax's Avatar
if i cut it.. where do you think i can take it to, to get it .. (what do you call it) that screwing part... where the **** goes on.. any suggestions? home depot is there a machines there that would let me do this? advice please
Old Mar 26, 2006 | 07:30 PM
airmax's Avatar
will cutting the shifter.. effect the performance in anyway?
reason why i'm asking because i understand that your shifter is sturdy like the oem one and by cutting it, that will make it lighter.. therefore the throws won't be as smooth.. that is what i'm afraid of..
Old Mar 26, 2006 | 07:42 PM
4bidden's Avatar
If you cut it shorter I'd suggest not using higher than the middle hole. Decreasing the lever height also decreases the leverage you have on the cables to shift gears. The shorter you make it, the more feedback you will have from the transmission. This DOES NOT mean you are harming the transmission, just means that you are feeling more of what is going on inside the transmission that the rubber bushings on the base plate and ends of the shift cables try to resonate.
You could take it to a machine shop and have them buzz some off the end and re-tap the end for probably $10 or something.
Old Mar 26, 2006 | 08:45 PM
vietkazie's Avatar
Default Re: (4bidden)
hi i was wondering if i bought a forbidden short shifter and i'm from california (zip code 94619) how long would it take to come? and total for a bronze would cost 133 with shipping? and to make the shifter lower, is the first hole at the bottom the one to put it on? which hole is to make it the same height as the stock height? sorry for the n00b questions.
Old Mar 26, 2006 | 09:32 PM
4bidden's Avatar
Default Re: (vietkazie)
I have bronze in stock. You would have it within 2-3 days.
The holes adjust the throw distance, not lever height. I suggest the middle hole.
Old Mar 26, 2006 | 09:34 PM
i took your suggestion about the middle hole...i used to have it of the top one, but the middle is more streetable
Old Mar 26, 2006 | 10:10 PM
airmax's Avatar
Default Re: (95greenlude)
Good idea to cut from there? or little higher little lower?
after cutting i must make it skinny on the top again huh by shaving it then tap-it..
gonna be a lot of work.. machine hmm.. would lowes, homedepot do it? those are the only machine shop that i can think of with actual machines to do so.. suggestions.
Old Mar 26, 2006 | 10:11 PM
4bidden's Avatar
Well you can thread all the way down to where it gets bigger to gain the extra .5-.75'' I mentioned. Other than that you'll have to find a machine shop in your area to trim the rest.
Old Mar 27, 2006 | 08:17 AM
EK9-Stealth's Avatar
whats the diff between 4th gen and 5th gen.. accords and preludes? I bought a h22 swap not to long ago and it didnt come with shifter and cables. The dude that i bought the motor from told me he will find me cables and shifter and he did, but i dont even know what car it came from, but it works. Is there any homework i should do before i get a short shifter or will they all be compatible?
Old Mar 27, 2006 | 08:20 AM
98vtec's Avatar
moderator emeritus
Default Re: (EK9-Stealth)
damn jeremy. I may have to sell my lean
Old Mar 27, 2006 | 04:07 PM
4bidden's Avatar
If you did a H series swap in your Civic you're likely running 4gen Accord since they are the easiest and cheapest to find. Do you have a picture so I can confirm?
Old Mar 27, 2006 | 05:17 PM
M2B4's Avatar
i work at home depot tomorrow i will check with plumbing to see if we can re thread. i will let yall know 2 morrow
