FS: 5.1 surround speakers home audio
Old Mar 25, 2006 | 07:33 PM
digitalcongo's Avatar
Default FS: 5.1 surround speakers home audio
i know your first reaction to jensens will be uhg...
but the powerstation series is good stuff...
i've heard thiese once set up and it was quality sound imo...so i bought them...
even the smallest pair in this set (jp500) are rated at 200watts @ 8ohms each and 55hz to 25k hz...not bad
the whole setup is new...i've never used them other than when i tested each one after purchase from a music shop
we have in this setup:
2 powered subs jp10sw ::: 75w rms ea @ 4ohm
2 centers jpc25 (these were going to be my main FL & FR) ::: 150w rms ea ::: 80-20k hz 8ohm
A high output 3-way w/ horn jp1200 (this would be my center) ::: 300w rms 35-25k hz - 92db 8ohm
2 jp500's 200w rms ea 8ohm
1150 watts
all are protected at each corner and carpeted
every woofer on every speaker has tight mesh rigid grills
all speakers are made with 15mm mdf
the subs are thicker i am pretty sure
All SE7EN PIECES FOR $160 !!!
Will deliver up to 250 miles from cleveland for $0.25/mi
all specs for these speakers can be found by punching in the model # in google websearch
i have more stuff around
electric oil pressure gauge new in package w/ sender and bracket...its lighted w/ black face ::: $25
electric cutoff custom made by QTP quick time performance for up to 60lbs of boost !!!
has flanges,gaskets & hardware...testpipe length...requires welding ::: $200
fender jazz bass with custom neck inlays & bridge...active pickups...midi pickup...
most awesome bass i have ever played....has a nanocompressor and monster cable ::: $525
Old Mar 27, 2006 | 08:29 AM
Default Re: FS: 5.1 surround speakers home audio (digitalcongo)
bump
Old Mar 28, 2006 | 10:45 AM
bump
Old Apr 2, 2006 | 09:42 PM
will blow womens clothes off
stock94ex
Mar 19, 2008 03:20 PM
t0ekn3e
Audio / Security / Video
Dec 27, 2007 05:23 AM
Odessa
Jul 11, 2004 08:48 AM
