Quick Release Horn Hookup Questions w/ Pics Omnipower setup
Yes, I searched and did not find the answers I need give the scenario I have w/ this setup below.
This is the Omnipower kit for an EF:
The hub has one green wire
The quick release has two wires, red and black
Anyone have an idea how this hooks up and where to properly feed these wires through?
I would like my horn to work, but it simply does not come together when thinking/trying scenarios. Also, Omnipower did not provide any instructions.
Pics of the stuff/wheel/etc:
Sorry, no ideas, but does this hub have dual bolt patterns on both sides of the hub? I want to get one, but I have a Personal wheel with personal hub and most of them are just made for the Momo hub.
Also, is there any play in the steering wheel when its on?
Bump for you! I'll be looking up this topic in a couple of weeks.
connect the green to the red and just ground the black wire.
you can pinch the wire between the hub and quick release to ground it.
remember to strip the wire.
good luck with it!
good luck with it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atc5 »</TD></TR><TR><TD CLASS="quote">
do i hook a wire to the metal piece clip shown in the 5th picture?
thanks</TD></TR></TABLE>
no that will ride on the back of the adapter you have in your hand in the second to the last picture. my susgestion would be to look at the back on your stock steering wheel and see how it operates. that metal piece sticking towords the the camera is like a brush type thing and rides on a copper ring on the back side of the stock steering wheel. thats what makes the contact between the column and the wheel. connect the green to the red and ground the black and try it out, you should be fine
hialeahzbg
Jan 24, 2012 01:34 PM
cmross13
10
Feb 27, 2010 11:39 AM
greenzchatch
Jun 25, 2009 01:04 PM
