brakes knocking
Old Mar 25, 2006 | 05:39 PM
theemaddhatterr's Avatar
Default brakes knocking
i have a 89 honda crx hf what happens is when i am slowin down and lightly press down on the brakes my drivers side brakes make a knockng noise and you can feel it in the car it only happens when the brakes are pressed lightly but if you press the brakes hard 1-2 and hold it'll stop any one know wht could be causing this
Old Mar 25, 2006 | 06:04 PM
civic_dork's Avatar
Default Re: brakes knocking (theemaddhatterr)
brake pad material buildup on disc/drum. most likely, most common.
brake disc warped (usually misgiagnosed for above), somewhat common.
swollen/clogging brake line. totally likely.
worn or broken suspension/steering parts... very likely.
bad tires... totally possible.
basically could be anything, never know without looking at it and inspecting.
Old Mar 25, 2006 | 08:22 PM
Crx Jimmy's Avatar
could be the radius rod as well
Old Mar 25, 2006 | 09:57 PM
CRX7's Avatar
Default Re: brakes knocking (Crx Jimmy)
Jack it up and shake the whole wheel assembly, see if anything's loose. When mine did this, the wheel was loose. My lesson, always torque by hand, never trust an impact wrench.
pilotboy
Apr 14, 2018 04:31 PM
v8killaz
Nov 8, 2010 08:42 AM
patrickstar
Suspension & Brakes
Apr 24, 2009 12:41 PM
JDM_SOHC
Mar 23, 2006 05:11 PM
See Are X
Jun 1, 2003 02:51 PM
