exhaust problem
Old Mar 25, 2006 | 05:24 PM
noopsITR's Avatar
Default exhaust problem
okay, a month ago, i swapped out the C5 and went with the jdm 98 spec. i had to use the header from the C5 on the 98 spec cause it wouldnt fit onto the stock cat. i want to use the 4 into 1 header so i got a 2.5" omni power test pipe. so, my question is if i put on the jdm header with the test pipe, will the test pipe bolt onto the stock 2.25 b-pipe? i want to know before i get under the car and find out the hard way. thanks.
Old Mar 25, 2006 | 05:25 PM
Jon D's Avatar
Default Re: exhaust problem (noopsITR)
what was wrong with the C5?
Old Mar 25, 2006 | 05:31 PM
noopsITR's Avatar
Default Re: exhaust problem (Jon D)
the C5 was reaching high miles, i just thought it would be a good time to swap it out. the jdm spec runs soooo much better. i lucked out when i bought it because the seller didnt have the stock jdm p73 ecu so he added a spoon p73 with the purchase. i was planning to use the C5 in my hatch, just have to get everything i need for the swap. but do you know the answer to my question?
Old Mar 25, 2006 | 06:12 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noopsITR &raquo;</TD></TR><TR><TD CLASS="quote">i was planning to use the C5 in my hatch</TD></TR></TABLE>
If you care at all about the resale of your car, do not use the original engine in another car.
Old Mar 25, 2006 | 06:38 PM
noopsITR's Avatar
Default Re: exhaust problem (Reid)
yeah, i heard something like that from my friend, the engine is just kicking it in my garage. the hatch is my new project, i was gonna use the C5 as a last resort kinda thing. if i ever sell the R, i was gonna swap it back in.
PowerLeg
Oct 3, 2009 11:23 PM
-faded-
Jul 27, 2007 05:57 AM
SpoolnEG6
Feb 12, 2005 04:05 PM
92TypeR
Oct 19, 2002 03:47 PM
R264
Jul 29, 2001 12:50 PM
