EF B-Series Hasport Mount Question?.....
I have my b18a1 ready to put in my 91 rex and the stock B-Series bolts do not fit. Some are to small and some need different diameter. What the hell.... Can anyone help me figure out what size/length/diameter that these bolts need to be... Thanks in advance...
Austin
Austin
http://www.hasport.com , has the bolts listed on the site under instructions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMatters »</TD></TR><TR><TD CLASS="quote">I believe only the rear mount is the only one that actually bolted on correctly.
TTT</TD></TR></TABLE>
When I swapped a B16 into my REX I used all the bolts from a '92 GSR I had and everything bolted right up, all the bolts switched right over to my Hasport mounts, I say just go to acura and buy the bolts you need unless you can find them in a junk yard.
TTT</TD></TR></TABLE>When I swapped a B16 into my REX I used all the bolts from a '92 GSR I had and everything bolted right up, all the bolts switched right over to my Hasport mounts, I say just go to acura and buy the bolts you need unless you can find them in a junk yard.
