wheel size 15x7 too wide?on a del sol?
Old Mar 25, 2006 | 02:59 PM
Elwuudz's Avatar
Default wheel size 15x7 too wide?on a del sol?
I was looking into buying some PIAA wheels
will 15x7's 4x100 be too large/ wide?
I will be riding 2in down in front and 1 3/4 in rear on tein ss
I was also thinking of investing in a suspension techniques swaybar kit
the 1in fr 3/4 rear bars
please offer up any suggestions and helpful advice
Old Mar 25, 2006 | 03:07 PM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
Default Re: wheel size 15x7 too wide?on a del sol? (Elwuudz)
depends on offset but i believe piaa wheels come in mostly fwd and 15x7 isnt that big so you should be good to go
Old Mar 25, 2006 | 04:57 PM
Slopoke's Avatar
Default Re: wheel size 15x7 too wide?on a del sol? (DaKINE-Ek)
But unless you are running an extreme offset or tire size, you should be ok.
Im currently running 15x7, 41 offset, and 205/50/15 tires, with more drop than you have and I dont rub at all.
Old Mar 25, 2006 | 09:12 PM
nsxtasy's Avatar
H-T Order of Merit
You're working backwards.
FIRST you should decide what wheel diameter you want to use.
THEN you should decide what size tire is best for your car.
FINALLY you should decide what width wheel will work with that size tire.
In the case of a del sol, the proper size tire for 15" wheels (the one that will maintain the accuracy of the speedometer and odometer, and won't rub on the fender wells) is 195/50-15. And the best size wheel for a tire that size is 15x6, not 15x7.
Old Mar 28, 2006 | 05:58 AM
Autoworks's Avatar
Default Re: wheel size 15x7 too wide?on a del sol? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You're working backwards.
Actually, giving the offset of the wheel is a +40 (which we don't know because it wsn't stated) a 15x6 or 15x7 would work perfectly fine with a 195/50-15, 195/55-15 or a 205/50-15 and wouldn't scrub
Old Mar 28, 2006 | 06:23 AM
RARE_EG2's Avatar
im on 15x7 with a +38 offset..195/50/15's and i rub in the front and a little in the rear just because of how low i am..
with your chosen ride height you should be ok..
Sylendrian
Jan 6, 2019 05:05 PM
cupofjoe619
Feb 9, 2016 06:16 AM
ej0513
Jan 18, 2009 07:10 AM
Elwuudz
May 2, 2006 11:32 PM
ITRswapandslow
Nov 15, 2003 02:18 PM
