NEED JDMB18C1 OBD-2 HELP
Old Mar 25, 2006 | 01:50 PM
9WON4's Avatar
Default NEED JDMB18C1 OBD-2 HELP
I havent touched the timing on my jdmb18c1. Rpm put in a new belt with pumps at swap time......the motor ran like a Gem for a full year.....Then recently, I took it to the track and we experienced some sputtering on the way(before we got there). I bought new plugs which are pre-gapped from acura(at the dealer-oem)......and when I pulled them....the plugs and bottom of the spark plug boots we're covered in oil. I did the required valve cover gasket(cause thats what that is-the grommets were there problems) repair. Motor seemed to run harder than ever for like 2 days until the sputtering AGAIN at 2000-3500 rpm's.............I was beside myself......I have changed the wires and the plugs twice(my 1st set got drenched in oil before I repaired the valve cover gasket set).........the dist. rotor and cap are soooo clean.....No Red dust .....just dust from packin' 30,000 miles on the motor. It stops bogging and sputtering after I floor it.......How do I stop this........it ran great for so long.....and the valve cover gasket was prolly never the MAIN problem all along!!! I had my racing mechanic/pal look at my car.....he diagnosed the distributor and wires to ensure they were getting a pulse he said they were and that it was most likely an ignition problem. I have received no codes......I only wish I did!!! Could this be an ECU Problem.........(should I get a usdm 0bd21 ecu or a jdm?) thanks for ANY help......Im really confused.
Old Mar 25, 2006 | 01:53 PM
riceburnerryan's Avatar
you are using the highest octane gas im assuming right? and what ECU are you running by the way?
Old Mar 25, 2006 | 02:57 PM
professor poon's Avatar
Default Re: NEED JDMB18C1 OBD-2 HELP (kidkanedtx)
can't help ya, I'm as confused as you are, but just so that you don't confuse others, the JDM GSR motor is a B18C, not a B18C1
Old Mar 25, 2006 | 05:39 PM
9WON4's Avatar
Default Re: NEED JDMB18C1 OBD-2 HELP (professor poon)
my bad........I run the stock sir-g ecu JDM......and yes high octane and new fuel filter at the swap........its been roughly 23,000 miles since the swap......
Old Mar 26, 2006 | 10:43 AM
LSV_REX's Avatar
In the valve cover there are some gaskets around the spark plug holes. In my friend's CRX they got old and started leaking oil into the spark plugs. We just put honda-bond in there until he could order the new ones. Hopefully that helps. Even if your mechanic said maybe an ignition problem, this still doesn't solve why you have oil in your spark plugs.
Old Mar 26, 2006 | 02:42 PM
9WON4's Avatar
Default Re: NEED JDMB18C1 OBD-2 HELP (LSV_REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSV_REX &raquo;</TD></TR><TR><TD CLASS="quote">In the valve cover there are some gaskets around the spark plug holes. In my friend's CRX they got old and started leaking oil into the spark plugs. We just put honda-bond in there until he could order the new ones. Hopefully that helps. Even if your mechanic said maybe an ignition problem, this still doesn't solve why you have oil in your spark plugs.</TD></TR></TABLE>
i already did those.....it was the 1st thing i replaced
2ffu
Sep 13, 2009 04:14 PM
9WON4
Apr 19, 2006 06:11 AM
9WON4
Mar 26, 2006 06:17 AM
JMinSi2000
Aug 27, 2004 07:22 PM
