my radiator is clogged......will flushing it fix the clog???
Old Mar 25, 2006 | 01:37 PM
EG_93Civic's Avatar
Default my radiator is clogged......will flushing it fix the clog???
just like the topic said....and if i do need to replace it, where can i find one under $200
Old Mar 25, 2006 | 01:58 PM
riceburnerryan's Avatar
if you need to replace it you can get one for under 200 bucks
Old Mar 25, 2006 | 02:12 PM
Archidictus's Avatar
Unceasing Measure
Default Re: my radiator is clogged......will flushing it fix the clog??? (EG_93Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_93Civic &raquo;</TD></TR><TR><TD CLASS="quote">just like the topic said....and if i do need to replace it, where can i find one under $200</TD></TR></TABLE>
Advance Auto and Napa both have good Civic radiators for $100. They're larger and better than stock. I use them exclusively.
And no, if your radiator is clogged bad enough that pressurized coolant won't go through it, flushing it will just damage the radiator. Replace it and move on.
Old Mar 25, 2006 | 02:32 PM
EG_93Civic's Avatar
Default Re: my radiator is clogged......will flushing it fix the clog??? (Archidictus)
any comments on buying from streetimport or yonaka??
Old Mar 27, 2006 | 06:58 AM
EG_93Civic's Avatar
ttt
sittingonROTAS
Jan 13, 2007 12:42 PM
hks369
Dec 24, 2006 12:43 PM
eg6ryder
May 5, 2006 07:03 PM
eecc
Acura TL, RL & ZDX
May 14, 2005 03:29 AM
tkHBseries
Feb 19, 2005 06:48 PM
