Well, hatch now runs....but runs like crap. help?
Old Mar 25, 2006 | 01:33 PM
HatchBox's Avatar
Skoobie no more...
Default Well, hatch now runs....but runs like crap. help?
Alright, the car is throwing a IACV code. So I have to replace that. But i dont beleive that has anything to do with my current problem.
Car takes a while to crank over (first vid)
I have the battery in the rear. Could that be it? Wtf...
http://vids.myspace.com/index....7&n=2
dont mind the girlfriend. haha
Second, the car runs like poo... idles semi rough, but when you snap the throttle it bogs. When you hold the throttle open it will backfire though the intake...
As far as i know the timing is correct.
My car has a b16a1 with walbro 255 fuel pump.
http://vids.myspace.com/index....9&n=2
Old Mar 25, 2006 | 01:56 PM
Ak_ef9's Avatar
Default Re: Well, hatch now runs....but runs like crap. help? (HatchBox)
sounds like the timing is off. checked it?
Old Mar 25, 2006 | 02:07 PM
g-ride-si's Avatar
Default Re: Well, hatch now runs....but runs like crap. help? (Ak_ef9)
have you checked the firing order?
the tps and the map sensor(or maybe the iacv) i believe have the same plug make sure you have them right and not switched, that will make the car run like that as well.
Old Mar 25, 2006 | 02:20 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Well, hatch now runs....but runs like crap. help? (g-ride-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the firing order?
the tps and the map sensor(or maybe the iacv) i believe have the same plug make sure you have them right and not switched, that will make the car run like that as well. </TD></TR></TABLE>
Tps, map would throw codes if mixed.
Firing order is correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the timing is off. checked it?</TD></TR></TABLE>
would this cause the long crank to start?
Old Mar 25, 2006 | 03:21 PM
g-ride-si's Avatar
timing being off would def cause that but i thought you said timing was on? IACV can cause problems similar to that too though, you dont need to replace it just clean it out really good with carb cleaner and put it back on. have you reset the ecu to see if any more codes have popped up?
Old Mar 25, 2006 | 04:53 PM
thrty8street's Avatar
how do you reset the ecu?
Old Mar 25, 2006 | 04:59 PM
g-ride-si's Avatar
Default Re: Well, hatch now runs....but runs like crap. help? (thrty8street)
remove the hazard fuse.
civic_dork's Avatar
Pull the hazard fuse for a couple minutes... or i prefer disconnecting battery for few minutes. Unless ya cherish your clock and radio presets.
Old Mar 25, 2006 | 08:28 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Well, hatch now runs....but runs like crap. help? (civic_dork)
anyways, it turned out that before i fried my injectors and resister box
(the resiser box was not hooked up right)
Im sure this could mess up the drivers in the ECU.
Would a bad ecu cause this conditon?
Old Mar 26, 2006 | 08:56 AM
HatchBox's Avatar
Skoobie no more...
timing looks dead on.
Old Mar 26, 2006 | 09:24 AM
3s0n3's Avatar
my buddies type r had water in the plug holes grounding the plugs out and it sounded just like that..... u didnt wash it did u ?
Old Mar 26, 2006 | 09:26 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (3s0n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote"> u didnt wash it did u ?</TD></TR></TABLE>
nope
Old Mar 26, 2006 | 09:42 AM
DADADAAAMN's Avatar
u get it fixed yet? bump for you because we had the same prob. in a hatch we where working on.
Old Mar 26, 2006 | 09:49 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (DADADAAAMN)
not fixed, need help, suggestions,
anything...
Old Mar 26, 2006 | 02:04 PM
PTskater944's Avatar
Default Re: (HatchBox)
What about vacuum leaks? You mentioned backfiring through the intake manifold. My car just blew its intake manifold gaskets and that caused it to backfire at idle. Run some compressed air through the IM and listen for leaks.
Old Mar 26, 2006 | 03:17 PM
chadmasterc's Avatar
Default Re: (PTskater944)
Did the car run previously? If so what have you done to it between now and then?
Old Mar 26, 2006 | 03:18 PM
Crx Jimmy's Avatar
still sounds like injector problems, like they are not firing in the right order
Old Mar 26, 2006 | 03:22 PM
ruffie_PL's Avatar
Check all vacuum wires and gaskets and MAP sensor.
mrtoastyjr's Avatar
did you snap a t belt? sounds almost like bent valves or mabey even vtec engauging at low rpm. did you check your tps? whats the voltage read with the throttle closed? do you have a cat on it? mabey its clogged, try disconnecting the cat from the header and run it
Old Mar 26, 2006 | 03:55 PM
Ak_ef9's Avatar
Default Re: (mrtoastyjr)
hey the pictur looks like your timing it off It is suppoesed to say up not pr3. So the timing is off
Old Mar 26, 2006 | 05:22 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Ak_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">hey the pictur looks like your timing it off It is suppoesed to say up not pr3. So the timing is off</TD></TR></TABLE>
The PR3's have Arrows pointing up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">did you snap a t belt? sounds almost like bent valves or mabey even vtec engauging at low rpm. did you check your tps? whats the voltage read with the throttle closed? do you have a cat on it? mabey its clogged, try disconnecting the cat from the header and run it</TD></TR></TABLE>
Nope never snapped a belt. I am using the hasport vtec harness, but i can check that, but i doubt it.
I switched the wires at the tps, so that should be reading correct, but i will check tomorrow, just to be sure.
I have a gutted cat.
Fuel pressure is at 37-40 right where it should be also. So its not fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">still sounds like injector problems, like they are not firing in the right order</TD></TR></TABLE>
Yep thats what im thinking, The car ran before i had the problem with the resister box. So Im deffinatly thinking i messed something in the ecu up when i fried the injectors and reister box. I will be borrowing my friends ECU to see if it is that.
I Really hope its just a bad ecu. If not im going to have to check the wires from the injectors to the Ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadmasterc &raquo;</TD></TR><TR><TD CLASS="quote">Did the car run previously? If so what have you done to it between now and then?</TD></TR></TABLE>
Wow, very long story. I have been working on the car for like 2 years. ( i have been busy) Well it ran fine sorta after i got it in. I must have did a poor wiring job because later on the resister box did not have continuity between the Main relay and or the ECu. so the Injectors were being run off 12v i beleive (should be 6v) So the injectors were bad, and the resister box was as well (out of Ohm spec). Since then i just rewired a whole new harness (the right way this time) and put it in and thats where i am now.
I left out alot of stuff i did, but that is all that is related to this problem
Old Mar 26, 2006 | 10:45 PM
Ak_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
but there should be a up imprint. The problem might be that the cams are reversed and need to be put back into place. check the cams sprocket to see if i am wrong but I doubt it. Mine has pr3 and up
Old Mar 27, 2006 | 01:10 AM
hatchyboy89's Avatar
yea when my timing was off it did the same thing and yea there is a up mark on there and the pr3 should be down, so that is most prob it
Old Mar 27, 2006 | 05:48 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (hatchyboy89)
But the Pr3 is in A arrow that is pointing up...
Can anyone confirm that the PR3's should be down.
Like with a picture?
Thanks.
I have not touched the cams, so how would they be reversed, Unless the motor came from japan with the cams reversed?
Old Mar 27, 2006 | 08:14 AM
HatchBox's Avatar
Skoobie no more...
Ok it turns out i was wrong and the arrows are pointing down when the 2 marks are lined up.
Does this mean i have the intake and exhaust cams in backwards?
how do i tell the diff between the intake and exhaust cams. are thy marked?
