SHAKING when doing over 70 mph my theet are about to fall
Old Mar 25, 2006 | 12:46 PM
EK FLY's Avatar
Default SHAKING when doing over 70 mph my theet are about to fall
hi
I have a bad problem on my car everitime I go on the beltway(over 60 mph ) my car start shaking like a ************ everithing shake even when I let go of the gass I have no clue why .
the other day i took it to pepboys to get it alingned and he said to check on the iner and outher tie rods and that he could not do the alingment bc of that ...
what could it be ? anyone havd a clue
Old Mar 25, 2006 | 12:52 PM
SlammedDC2teg's Avatar
Default Re: SHAKING when doing over 70 mph my theet are about to fall (TURBO-WAWA)
you should get your tires balanced.
Old Mar 25, 2006 | 01:07 PM
cm zak's Avatar
if that doesnt help, MAYBE alignment, but slammeddc2teg is right, its probably imbalanced tires.
Old Mar 25, 2006 | 02:16 PM
mike9571's Avatar
Default Re: SHAKING when doing over 70 mph my theet are about to fall (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">you should get your tires balanced.</TD></TR></TABLE>
I agree. If it was your alignment the car would pull left/right. Check to see if your tires have uneven wear. If so it would really cause unbalance of tires.
Old Mar 25, 2006 | 02:19 PM
Sifu's Avatar
^^ Do that or drive slower
Old Mar 25, 2006 | 05:05 PM
hondanuts's Avatar
i had this prob before and it was my tires being unbalanced
Old Mar 25, 2006 | 05:06 PM
TEGGRY's Avatar
The same thing happend to me. At first i thought it was my alignment or my unbalanced tires but it just turns out to be that i needed new tires. If your tires are not good anymore, get new ones. Usually it is just the tires that cause that problem, well it was in my case.
Old Mar 25, 2006 | 05:22 PM
LordAphotic's Avatar
maybe your rims are bent. i had the same prob. it was cause one of my front rims was bent.
Old Mar 25, 2006 | 07:00 PM
scotts93ls's Avatar
sounds like it could be a broken belt in the tire, happens alot get new ones. or could be some dirt stuck to the inside of the rim
Old Mar 29, 2006 | 04:08 PM
EK FLY's Avatar
Default Re: SHAKING when doing over 70 mph my theet are about to fall (scotts93ls)
yea u guys were right it was the tires..... btw do u guys know how to change iner and outer tie rod ?
07siftw
Honda Civic (2006 - 2015)
10
Jun 2, 2008 07:08 PM
HOUSTONb
Jul 9, 2007 10:42 AM
da_33
Dec 14, 2006 03:56 PM
jrv2u
Dec 1, 2004 10:06 PM
camera obscura
Apr 9, 2003 06:38 PM
