Anybody know if you can/where you can get this stuff...
The oem plastic that covers up the door guts. Honda doesnt offer it here locally that ive seen. If its not available, has anyone done a DIY that can give me pointers on what adhesive and meterials used.
(I jacked the pic from another thread.. so thanks to d4rkn1t3
TIA.
)TIA.
You could always check ebay, a junkyard, or even a swapmeet. As far as adhesive locations, i'm not sure but some manuals have interior installation/removal info. Not sure how much help this will be....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">it's called a door panel, look in the honda-tech marketplace, there's tons</TD></TR></TABLE>
i think he means the plastic under the door panel
I once had to replace mine. I just used vapour barrier (construction material) and some caulking. I never opened the door open later to see how well it had held up. I just had the stuff lying around the house.
hondaautomotiveparts.com (look under door panel) for the real replacement. Essentially its nothing more than thick plastic sheeting attached to the door with a rubbery adhesive. You could buy it or do it yourself with most likley the same result and im sure any multi purpose caulk would be fine for the job.
davzing
Aug 21, 2006 04:48 PM
ex voto
42
Mar 16, 2005 10:14 AM
