Stock prelude with CAI, inline fuel pump? h22
I am wondering if i'd see any gains from putting an inline fuel pump on. I have a seen a few on Ebay cheap but not quite wanting to spend the money on an MSD pump due to the cost.
http://cgi.ebay.co.uk/ELECTRIC...wItem
I would also like to run a dry 50 shot nitrous setup in the future, would it help out here also?
I have a B&M fuel pressure regulator from a past setup if it will help?
Thanks
Thanks
I know the filter will not require the extra fuel but if adding nitrous is it a wise idea to add the pump?
Or can I just run the nitrous on my stock engine, and therefore stock fuelling setup
cheers
cheers
Thanks, thats all I needed to know.
I may contemplate one for my other setup later down the line, it has a walbro 255lph, 450dsm injectors and fuel pressure regulator. shooting for ~400hp at about 15-25PSI
not that its adding anything to this discussion, but 15-25psi is a pretty big range......400hp can be had out of a built h22 with a lot less boost
i believe a 255lph pump will be plenty for that setup also, you shouldnt need an inline pump
The block is sleeved and capable of 32PSI I believe. I shall run whatever PSI takes me to 400hp cuz thats where the driveshafts, clutch start breaking if the stock gearbox hasnt blown already.
DroppedTegra
Jan 18, 2002 03:13 PM
