stupid stuck tubes...
Old Mar 25, 2006 | 08:24 AM
rice a roni's Avatar
Default stupid stuck tubes...
take off rusted bolts and screws off is easy but anyways im having problem getting the two filler neck hoeses off of from the rubber hoses that connect to the gas tank. should i just cut it? or is there a better way around it? any recommendations would be nice.
Old Mar 25, 2006 | 02:02 PM
badboyr66's Avatar
Default Re: stupid stuck tubes... (0mghi2u2)
Well you can cut them. Another way is to get a tool that looks like it is a center punch with a bent tip. It makes a 90 degree angle at the end ... you can use that to kinda lift the the rubber and break it lose
Old Mar 26, 2006 | 09:30 AM
Default Re: stupid stuck tubes... (badboyr66)
wow i finally got it out after 30 minutes. i didnt cut them. i just put some wd-40 on it and used a flat to pry them apart...and i didnt rip the tubes either. damn wisconsin rust is bad for this.
d16sandrail
Welding / Fabrication
10
Feb 20, 2010 06:30 AM
ClarkS40
Mar 8, 2009 06:28 AM
56civic
Honda Civic (2006 - 2015)
Dec 10, 2006 10:52 PM
LostCRX
25
Jan 30, 2005 12:22 PM
kim_2_da_chee
13
Jan 8, 2003 12:39 AM
