REar caliper is too tight when it goes back on!
Old Mar 25, 2006 | 04:31 AM
gtowni3's Avatar
Default REar caliper is too tight when it goes back on!
sup guys just did my rear brakes.....with the e brake off......and i compressed the piston with a large flathead and the caliper went on smoothly, but then when i tighten it , its very hard to spin the rotor by hand.....what am i doing wrong??? thanks
Old Mar 25, 2006 | 05:17 AM
GranadaTeg's Avatar
Default Re: REar caliper is too tight when it goes back on! (gtowni3)
take it off, and do it again.
Old Mar 25, 2006 | 06:48 AM
jomama's Avatar
correct size rotor? are you doing upgrades of any kind? spacer/washer issues?
Old Mar 25, 2006 | 10:45 AM
93_teg_CT's Avatar
Default Re: (jomama)
Turn the caliper more.
Old Mar 25, 2006 | 10:49 AM
93_teg_CT's Avatar
Also, did you put the tire on and pump the brakes at all? They gotta like work themselves back into position. cause this happened to me, well I could move the rotor but it was hard, I hit the brakes and they like opened up more.
Old Mar 25, 2006 | 12:06 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: REar caliper is too tight when it goes back on! (93_teg_CT)
Compress/turn the piston all the way in as far as it can go in. Then put the caliper on. There's always going to be resistance when you try and turn a rotor by hand. When you get in the car, pump the brakes a few times to get the pad seated onto the rotor.
Old Mar 25, 2006 | 03:10 PM
Dogginator's Avatar
Daisy... Daisy...
Without the rotor, does the caliper move freely on the mounting pins?
Old Mar 25, 2006 | 07:02 PM
IN VTEC's Avatar
Maybe you didn't get the tab on the inner brake pad into one of the 4 slots on the caliper piston.
2gn9gencevg
Apr 18, 2004 11:35 AM
JDMlyfestyle
13
Mar 22, 2004 11:04 PM
JDM TypeR 307
Feb 27, 2004 06:07 PM
SonicGSR
Mar 31, 2003 05:55 PM
ajbones
Jul 10, 2001 05:02 AM
