question about reusable parts
runnin a d16z6 right now and plannin to swap in a b-series. can any of these parts be reused with the swap?
1. master clutch cylinder
2. short shifter
3. reverse switch
2. short shifter
3. reverse switch
I do believe the master clutch cylinder goes on a B just remove the 2 bolts on it then bolt it on the same place, short shifter depends if it's a GSR tranny or an LS tranny GSR most likely not LS I think it possible. Reverse switch ehhh if you talking about the harness plugging up to it then no prob there only wire harness mod was the obd 2 to obd 1 conversion kit you can get on ebay. Just need to change injectors on the harness. Sorry I don't have definate answers but I didn't see any post and didn't want you flying in the wind
1SLaMMeDC2
Jul 31, 2007 06:44 PM
