CTR Power Window Switches on USDM, dual window switches on RHD?
I found a great deal on a OEM Power Window Wiring Kit for CTR power door panels at jdmland.com. It includes almost everything you need.
[i]PHOTO COURTESY OF http://WWW.JDMLAND.COM[/i]
I am converting my CX's manual window to power. I am using the CTR Power Panels
Since this wiring harness if from a RHD vehicle, the "dual" window switch is natuaraly located on the right side of the car.
My question is, if I install this harness set up will I have the ability to use USDM EX/Si window switch panels so I'll have the dual window switch on the proper side of the cabin? Or is the wiring for that going to be proprietary to having those switches on the rhd?
What are my options?
-J
Modified by quicksilverej6 at 5:34 AM 3/26/2006
Modified by quicksilverej6 at 5:44 AM 3/26/2006
-J
bump...searched....
Could the harnesses be swapped from side to side?
Modified by quicksilverej6 at 5:45 AM 3/26/2006
KamiKazeEG
Dec 1, 2006 12:59 PM
litterbox
Sep 20, 2004 12:34 PM
Mikeman191
Apr 18, 2004 06:50 PM
