LSD: OBX vs Quife
Old Mar 24, 2006 | 06:57 PM
mrrugsr's Avatar
Default LSD: OBX vs Quife
Since im getting a new clutch and flywheel.....while im in there i was thinking of installing LSD. I see OBX is about 1/3 of Quiafe but can anyone tell me why? Which should I et. Any testimonies?
THANKS GUYS
Old Mar 24, 2006 | 07:04 PM
nickG's Avatar
Default Re: LSD: OBX vs Quife (mrrugsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr &raquo;</TD></TR><TR><TD CLASS="quote">Since im getting a new clutch and flywheel.....while im in there i was thinking of installing LSD. I see OBX is about 1/3 of Quiafe but can anyone tell me why? Which should I et. Any testimonies?
THANKS GUYS </TD></TR></TABLE>
probably because its at least 1/3 the quality...but i have experience w/ either
Old Mar 24, 2006 | 07:06 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: LSD: OBX vs Quife (nickG)
Quiafe hands down and you cant beat the lifetime warranty
Old Mar 24, 2006 | 07:10 PM
mrrugsr's Avatar
so should i save up for it then......hmmmm
where to buy, any links or is this another ebay thing
Old Mar 24, 2006 | 07:13 PM
Uncle Willie's Avatar
Default Re: (mrrugsr)
cant go wrong with lifetime warranty.
Old Mar 24, 2006 | 08:28 PM
Ichigo's Avatar
Default Re: (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">cant go wrong with lifetime warranty.</TD></TR></TABLE>
Means good qaulity stuff....
Old Mar 24, 2006 | 10:56 PM
mattcivic's Avatar
Default Re: (Ichigo)
im a cheap *** i got an obx worx fine axles slip in and out nice too. i guess i got lucky cuz i have heard tons of bad stories on them but it worx for me.
Old Mar 24, 2006 | 10:59 PM
solareclipseauto's Avatar
Default Re: (mattcivic)
obx
Old Mar 25, 2006 | 07:20 AM
turbo gsr
Guest
Posts: n/a
just installed a quiefe it can handle tons of power dont cheap out where it matters, like your trans, obx will probly do fine but who knows in the long run. deff. go with quiefe 1800-553-1055
Old Mar 25, 2006 | 10:24 AM
mrrugsr's Avatar
whats that #^ ? place to order one?
Old Mar 25, 2006 | 12:55 PM
chubz0r's Avatar
im going to be running a quife. i personally got mine from cap1320 in the sponsors section. i got it for 850 shipped a little while back. i think its 895shipped now though. but take a look in the sponsor section.
if you want to save some money i guess you could go with the OBX, i heard they are made differently now, so i dont think the problem wiht the axles getting stuck happens anymore.
good luck with whatever you choose.
Old Mar 25, 2006 | 02:21 PM
Sifu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">im a cheap *** i got an obx worx fine axles slip in and out nice too. i guess i got lucky cuz i have heard tons of bad stories on them but it worx for me. </TD></TR></TABLE>
Arent there newer revised ones out? From reading here some people have been saying that the newer stuff is good and works perfectly.
But then again I have no real experience so I cant comment
Old Mar 25, 2006 | 03:04 PM
Dogginator's Avatar
Daisy... Daisy...
Why not the ITR LSD? It too is a helical design and is OEM. (Of course this only works for the GSR transmission.) How much HP are you planning?
Quaife's lifetime warranty only covers if you shatter the unit. Since they provide no numerical data for quantifying the performance of their ATB LSD, there is no way that it can fail unless it shatters. The Helm manual has a check list to follow that allows the performance of the ITR LSD to be checked. (No, this does not consist of seeing if both wheels spin after dumping the clutch.)
Check Quaife's FAQ section. (Quaife FAQ) They will not even list a torque bias ratio, which is the key numerical parameter governing the performance of a Torsen style differential. I'm not saying that the Quaife unit is bad, just understand that their warranty is essentially meaningless.
I run the ITR LSD in my GSR transmission. I couldn't justify Quaife's price premium based on mere hand-waving.
Old Mar 25, 2006 | 03:11 PM
Miss_Bitch's Avatar
Default Re: LSD: OBX vs Quife (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">Quiafe hands down and you cant beat the lifetime warranty </TD></TR></TABLE>
You beat me to it!
Quaife all the waaaaaaaaaay!
Old Mar 26, 2006 | 01:14 PM
mrrugsr's Avatar
about 300hp now and 400 later
TQ mabye around 250ish+
Old Mar 26, 2006 | 03:11 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr &raquo;</TD></TR><TR><TD CLASS="quote">about 300hp now and 400 later
TQ mabye around 250ish+</TD></TR></TABLE>
Go with the Quaife, as it can handle higher HP than the ITR unit. Keep in mind what I said about the warranty above.
Old Mar 26, 2006 | 03:17 PM
JamaicanDM's Avatar
no comparison bra get the quife
Old Mar 26, 2006 | 03:49 PM
mrrugsr's Avatar
better do it once and right then wrong and many times
Old Mar 26, 2006 | 03:53 PM
HT Black OPs
Default Re: LSD: OBX vs Quife (JamaicanDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Why not the ITR LSD? It too is a helical design and is OEM. (Of course this only works for the GSR transmission.) How much HP are you planning?
I was on the assumption that ALL these tranny's with a 4.400 Final could fit a oem LSD from either the CTR/ITR, excluding the 98 spec.
http://www.allmotorhonda.com/t...s.htm
Which would mean that you can buy my NEW Civic Type R/Integra Type R LSD and slap it onto many differnt B-series transmission's. I'am selling it for the price of a OBX.
Old Mar 26, 2006 | 04:28 PM
96 GSR-T's Avatar
Old Mar 28, 2006 | 06:20 PM
MIDnightblackDA's Avatar
Default Re: LSD: OBX vs Quife (96 GSR-T)
CAMP1320 sells both quafie and OBX so give Tom a call. If you have the money go with quafie but if not go with OBX.
Old Mar 28, 2006 | 08:05 PM
Racermech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">.</TD></TR></TABLE>
Wow that is a nice response.........
Anyways, Do a lot of searching about OBX, all of there products seem to be pretty hit and mis. Some guys have great luck with there products (cams, LSD), other guys have had majore issues. I know there is a thread about an OBX lsd that "exploded"
Old Mar 29, 2006 | 06:05 AM
mrrugsr's Avatar
IM TALKING TO THIS GUY AT MY LOCAL "IMPORT" SHOP AND HE SAYS obx SUCKS IF YOU DONT KNOW WHAT YOUR DOING....(sorry bout caps)
I guess you have to inspec the OBX LSD and re torque bolts and what not. But after that its fine. He says he has it and has 512HP on his civic hatch. Works fine. Do i need a speedo and bearings etc.?
Old Mar 31, 2006 | 05:44 AM
mrrugsr's Avatar
anyone?
Old Mar 31, 2006 | 01:54 PM
Promina's Avatar
I'll be putting on my OBX LSD that I got for a good price next week. I'll let you know how it goes and drives. I guess the right way would be Quafie, but I didn't pay much for it so, I'm not worried.
