Integra High Beams...
What bulb size are the 94-01 Integra highbeams? Are they H4?
I got a DRL Module and would like to wire it up.
But i dont think its going to work if its another highbeam type.
I know i tried it in my Accord and eventhough i wired up the high, the low came on.
Thats because Honda uses one Ground for both headlights.
And if you know electricity, they take the shortest route.
All in all, the low beams came on at low wattage. It looked teh ghey!
But yeah, can anyone tell me what type of Highbeams are in the Integra.
Or can i isolate the highbeams by themselves....
Thanks in advance for all the replies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">9005</TD></TR></TABLE>
X2
X2
Theres two separate bulbs, not a dual filament single bulb like an accord.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Cord »</TD></TR><TR><TD CLASS="quote">Is there a way to isolate the highbeams or do they share the same ground as the lowbeams?</TD></TR></TABLE>
Everything eventually goes to the same ground reference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockNrollteg »</TD></TR><TR><TD CLASS="quote">do you want to have the high beams on alone? if that's what you're talking about, you can wire a separate switch for it.</TD></TR></TABLE>
Yes. But i have a DRL module.
If i wire up a switch my highbeams will be on at full power.
With the DRL module the lights come on at 10% power...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostWhiteDC4 »</TD></TR><TR><TD CLASS="quote">
Basically.
I see you're based out in Cali...
What setup do you have?
</TD></TR></TABLE>Basically.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote"> Theres two separate bulbs, not a dual filament single bulb like an accord.</TD></TR></TABLE>
That's correct. The high beam is a 9005 bulb (sometimes called an HB3 bulb). The low beam is a 9006 bulb (sometimes called an HB4 bulb). Neither one uses an H4 bulb.
hanginlow
Feb 4, 2003 04:28 AM
GrandMarkie
Jan 20, 2003 12:28 PM
