RS Machines Billet T/B Available in 68mm 70mm 72mm & 74mm $295
RS Machines Billet T/B $295
Available in:
68mm
70mm
72mm
74mm
Modified by RSMACHINES at 5:00 PM 3/28/2006
Available in:
68mm
70mm
72mm
74mm
is the map sensorhole drilled out? i can;t tell from the picture, i would prefer it not be since i am running another sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">is the map sensorhole drilled out? i can;t tell from the picture, i would prefer it not be since i am running another sensor</TD></TR></TABLE>
Sensor is drilled out.
Very nice piece.
Any dyno numbers on this unit?
Also, Did you monitor the intake resonances before and after using this item?
Did you run this item on a flow bench?
Now, with the BBTB with the intake manifold even be able to hold that air? If a motor is not setup properly this item is actually going to hurt performance. Bigger is NOT always better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE »</TD></TR><TR><TD CLASS="quote">Are those diameters at the opening, or at the throttle plate?</TD></TR></TABLE>
Yes then they taper in
GRS Motorsports
Jun 24, 2010 12:42 PM
