Weird 5th gen bogging problem..
I have had this issue for about a year now, but only recently has it started to happen alot more frequently.
No CEL lights so its hard to figure out.
Basically when I start my car, after it has been running for awhile, and I am driving, the car wont acknowledge the accelerator is being pushed down. It does go a bit, but if I floor it the car moves like a snail, and then all of a sudden it will wake up and take off like a bullet, almost like VTEC kicked in, but at like 2000rpm it happens.
It onyl does this a little bit, and then seems to run fine after I have drivne for 30 seconds or so.
Could this be a clogged cat or failing 02 sensor?
-Clean IAC valve
-Clean EGR valve
-Change Spark plugs - Done less than 10,000km ago
-Change Cap and Rotor - Same
-Run Sea Foam through the motor - Same
I guess I will try the first 2 and see what happens
thanks
-Clean EGR valve
thanks
ekjdm89
10
Jul 7, 2011 01:55 PM
Lifeeater46
Nov 10, 2006 11:48 PM
