Suspension & Brakes Theory, alignment, spring rates....
Changing Rotors
Old Mar 24, 2006 | 10:31 AM
Smash03's Avatar
Default Changing Rotors
I know this sounds like a dumb and obvious question. But if the front rotors, pads, and caliper are changed to aftermarket ones, is it required to change the brake lines and fluid?
Old Mar 24, 2006 | 10:34 AM
AutoXer's Avatar
Default Re: Changing Rotors (Smash03)
If you're taking the caliper off, you will loose some fluid and possibly get air in the lines, so you will need to bleed them.
Old Mar 24, 2006 | 10:42 AM
Smash03's Avatar
Default Re: Changing Rotors (AutoXer)
Yea I already knew that part, but what I meant was do I also have to change to aftermarket lines and fluid too. Sorry if I wasn't clear earlier.
Old Mar 24, 2006 | 10:52 AM
94eg!'s Avatar
#1 Super Guy
Loved
Help us out here...
What sort of aftermarket parts are you planning on using. If your going to be using calipers that are identicle to your OEM ones, then you do not need to replace the brake lines. You just use the old ones.
If your going to be using a different type of caliper, chances are you will need different brake lines to match.
If your removing the caliper, you will defiently want to completely bleed all the old fluid out of the brake system (since brake fluid becomes less effective at high temps with age). This means you must buy new fluid to put in. Unless you go to Honda & buy Honda brand brake fluid, any fluid you put in will be "aftermarket". Any Dot3 or Dot4 fluid works fine...
Old Mar 24, 2006 | 12:26 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smash03 &raquo;</TD></TR><TR><TD CLASS="quote">what I meant was do I also have to change to aftermarket lines and fluid too. </TD></TR></TABLE>
no, you dont have to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">If you're taking the caliper off, you will loose some fluid and possibly get air in the lines, so you will need to bleed them.
loose some fluid? possibly get air in the lines? im completely certain thats gonna happen!
MotorMouth93
Apr 12, 2015 01:54 PM
Newbie808
Mar 29, 2012 08:17 AM
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
billyhoe
Dec 29, 2004 08:23 AM
JeremyL
61
Apr 16, 2004 06:03 PM
