cuttin aluimuim ic pipes
Old Mar 24, 2006 | 10:12 AM
criitter7's Avatar
Default cuttin aluimuim ic pipes
what cutting tool should i use to cut my 3" alumuin intercooler pipes?
Old Mar 24, 2006 | 10:22 AM
HamiltonRex's Avatar
Default Re: cuttin aluimuim ic pipes (criitter7)
chainsaw
Old Mar 24, 2006 | 12:38 PM
Race Egr's Avatar
Default Re: cuttin aluimuim ic pipes (HamiltonRex)
butterknife
Old Mar 24, 2006 | 12:49 PM
project dc2's Avatar
Default Re: cuttin aluimuim ic pipes (NAPIER)
my rock hard nipples
Old Mar 24, 2006 | 05:56 PM
criitter7's Avatar
seriouly what can i use. band saw? we have this cut off saw but it does a shitty job and successfully took a huge chunk out of a brand new blade.
i tried searching and came up with nothing
Old Mar 24, 2006 | 06:21 PM
tony1's Avatar
lol, i use my bandsaw.
Old Mar 24, 2006 | 06:36 PM
criitter7's Avatar
Default Re: cuttin aluimuim ic pipes (tony1)
i tried the hard nipple way.....not so much
chainsaw....too messy
butterknife would have taken a long time.
thanks tony1
what kind of blade do you use. i was in the process of buying one a sears but they didnt have a metal cutting blade to fit it?
Old Mar 24, 2006 | 06:44 PM
ManBearPig4silly's Avatar
Use a wood cutting mitersaw with a reverse rake blade and some cutting wax. Gauranteed that it will cut like butter.
Old Mar 24, 2006 | 08:07 PM
ILLICON5000's Avatar
Default Re: (I4sillypwr)
get an angle grinder
Old Mar 25, 2006 | 04:30 AM
karmadhi's Avatar
Default Re: (ILLICON5000)
hacksaw
Old Mar 25, 2006 | 09:16 AM
aspec101's Avatar
Default Re: (karmadhi)
For a clean cut go with a band saw with metal blade. It will cut easily and leave a clean finish. Never tried a miter saw but I like to stick with what works and leaves a clean cut.
Old Mar 25, 2006 | 09:17 AM
rkeith's Avatar
Default Re: (aspec101)
I use a bandsaw with a little bit of cutting oil to keep the blade cool and from getting clogged. Works like a charm.
Old Mar 25, 2006 | 10:15 AM
Default Re: (rkeith)
ok honestly .. bandsaw. doesnt leave to much crap behind. cut off wheel works too or a big 14" blade cut off miter saw setup but its messy and its a bitch to clean up
Old Mar 25, 2006 | 11:22 AM
criitter7's Avatar
Default Re: (project dc2)
awsome
thanks gentleman for your help
Old Mar 25, 2006 | 08:27 PM
Bailhatch's Avatar
I use a big cut off saw. It leaves rough edge but I found a sharp utility knife is great for cleaning off the 'flaps' on the trailing edge of the cuts. Then I just face if with a belt sander. Quick and easy
Old Mar 26, 2006 | 06:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">Use a wood cutting mitersaw with a reverse rake blade and some cutting wax. Gauranteed that it will cut like butter. </TD></TR></TABLE>
I can vouch for this.
We cut aluminum track lighting at work with a mitersaw.. just wear saftey glasses.
The best way to cut almost anything for our cars.. would be a coldsaw. Cuts to the degree.
Old Mar 26, 2006 | 06:36 AM
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
The best way to cut almost anything for our cars.. would be a coldsaw. Cuts to the degree.</TD></TR></TABLE>
amen. I want a coldsaw.
Old Mar 26, 2006 | 03:47 PM
h22 civic's Avatar
chop saw
Old Mar 26, 2006 | 07:19 PM
Tyler H's Avatar
I use this for aluminum. http://www.jepsonpowertools.co....html
Almost no deburring at all.
RJ#9
Welding / Fabrication
Jan 19, 2009 06:18 PM
mbpowner
Honda Motorcycles
May 24, 2006 09:15 PM
Ca$h
Jan 13, 2005 02:22 PM
flip1199
13
Aug 16, 2004 05:56 PM
andypandy
Apr 12, 2004 01:28 AM
