94 si ... need some advice been without a car for a week
Old Mar 24, 2006 | 08:50 AM
RacingShoeBox's Avatar
Default 94 si ... need some advice been without a car for a week
haven a problem with oil i have a 95 gsr motor usdm in a 95 si hatch
i did an oil change last saturday and immedietly after that during the first vtec kick in it bogged and i started loosin oil like it was my job put 2 more filters of the same type fram 3593a the thing is orange with black writing and it seems it is still poping out every time after the oil change
im down to two things if its not the filter it is the oil gauge fitting i dbout this though because there is plumbers tape on it
someone also told me hondas sometime if the seal is not perfect have a release valve that lets go of the oil if the filter encounters a problem or fittment is off
the wierd thing is the filter origonally on when it was ok (hitting vtec all day 8k rev) was a fram white with orange writing this one is orange with black lettering... is this a different modle or is my code off
help a brother out
sorry 4 reposting in a different section im not gettin a reply and i need some help here cant keep beggin for rides 2 work
Old Mar 24, 2006 | 09:25 AM
Luserkid's Avatar
Default Re: 94 si ... need some advice been without a car for a week (GsrSiHatchie)
<FONT SIZE="10"> . </FONT> &lt;--- your friend and so is correct grammer.
So do you see an oil spill or just notice your gauge isnt where you think its suppose to be? (where is it at?)
If you see a spill you might have put 2 filter gaskets on, on accident. It happens check there.
EFz6er
Jan 2, 2014 10:21 AM
LoGaN-VanG
Nov 20, 2011 07:55 AM
Aphrodavid
Apr 7, 2009 07:39 PM
ceyazzie
Dec 20, 2008 07:52 AM
RacingShoeBox
Mar 25, 2006 08:37 AM
