gsr oil filter questions
Old Mar 24, 2006 | 08:14 AM
RacingShoeBox's Avatar
Default gsr oil filter questions
haven a problem with oil i have a 95 gsr motor usdm in a 95 si hatch
i did an oil change last saturday and immedietly after that during the first vtec kick in it bogged and i started loosin oil like it was my job put 2 more filters of the same type fram 3593a the thing is orange with black writing and it seems it is still poping out every time after the oil change
im down to two things if its not the filter it is the oil gauge fitting i dbout this though because there is plumbers tape on it
someone also told me hondas sometime if the seal is not perfect have a release valve that lets go of the oil if the filter encounters a problem or fittment is off
the wierd thing is the filter origonally on when it was ok (hitting vtec all day 8k rev) was a fram white with orange writing this one is orange with black lettering... is this a different modle or is my code off
help a brother out
Old Mar 24, 2006 | 08:41 AM
Default Re: gsr oil filter questions (GsrSiHatchie)
bump someone help me out
Old Mar 24, 2006 | 09:36 AM
vinai's Avatar
From what I understand your filter is leaking??? Any ways pull it off again and check to see if gasket from the old filter is still on the motor side. Some times you pull the old filter and the gasket is still stuck, and when you install a new filter it won't seal right and then you loose oil.
Old Mar 24, 2006 | 09:14 PM
Default Re: gsr oil filter questions (vinai)
didnt even think 2 look at that... the past few have been a real BITCH to get off iv ended up hammering a screwdriver in just 2 b able 2 get the leverage 2 get it off that may be it...
Old Mar 24, 2006 | 11:34 PM
TRE_'s Avatar
try getting an OEM one, or mobil1 makes a nice filter. what weight oil are you using?
Old Mar 25, 2006 | 03:16 AM
Sack Master's Avatar
Default Re: gsr oil filter questions (TRE_)
Plumbers tape? What did you do weld it on? Plumbers tape is made of metal. I'm guessing you meant teflon tape maybe?
As for your question. Sounds like your car is messed up dude. Maybe you damaged the threads on it or something. I find it hard to believe that you tried 2 more different filters and they were all bad. Maybe fram ran a bad batch of filters. You could probably make them replace your engine for that.
Old Mar 25, 2006 | 08:37 AM
Default Re: gsr oil filter questions (Sack Master)
aint the filter... made a new post its the oil pressure gauge
https://honda-tech.com/zerothread?id=1571438
Aphrodavid
Apr 7, 2009 07:39 PM
Aphrodavid
Apr 5, 2009 09:50 PM
coot_er
Aug 23, 2006 07:23 PM
RacingShoeBox
Mar 24, 2006 09:25 AM
RAB
Jul 20, 2002 01:01 PM
