Suspension & Brakes Theory, alignment, spring rates....
Bumpstop setups with koni yellows - Post em up! Also DA/DC shock conversion q's...
Old Mar 24, 2006 | 06:39 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Bumpstop setups with koni yellows - Post em up! Also DA/DC shock conversion q's...
What bumpstops are you guys using with Koni Yellows?
OEM rubber?, Energy Suspension polyurethane?, KYB w/ dust boots? What?
I'm want to do a 94+ front shock conversion on my DA with the konis, and don't have a clue of what bumpstops to get.
I want something that will go onto koni yellows without fitment issues.
Also, I was thinking... Koni Yellows are tailormade for each application, meaning 90-93 teg shocks are tuned differently than 94+ ones. Can using DC shocks on my DA be a bad thing because of this? Should I send them back to get retuned? Or would it be better to just stick with 90-93 shocks?
Rock on. It's Friday.
Old Mar 24, 2006 | 06:49 AM
.RJ's Avatar
.RJ
Default Re: Bumpstop setups with koni yellows - Post em up! Also DA/DC shock conversion q's... (^^whatnoobs
Use OEM, or get the bumpstops from Koni. Trim them to about 1" long.
Old Mar 26, 2006 | 08:38 AM
i found these from ground control. they have four to choose from.
http://www.ground-control-stor.../CA=1
g3teg97
Jun 18, 2013 01:19 PM
kevinm1981
Suspension & Brakes
10
Jul 12, 2009 01:13 PM
2DoorBandit
Suspension & Brakes
Nov 7, 2005 10:53 PM
redDAinteg
Suspension & Brakes
May 27, 2005 02:05 PM
