Driving with oil leak?
Old Mar 24, 2006 | 06:32 AM
NoVALude's Avatar
Default Driving with oil leak?
Ok, so I am pretty sure that the seals are bad and leaking oil, but the car still runs and drives fine. After a few minutes of driving, smoke starts coming out from under the hood.
What I want opinions on is driving about 45 minutes to where I am going to be doing the engine swap....think I can make it? If I just fill with oil and not drive like an idiot, what are my chances of getting there (with smoke coming out)
Old Mar 24, 2006 | 06:40 AM
syntax.'s Avatar
Default Re: Driving with oil leak? (NoVALude)
as long as you top it off before you start and its not gushing out, youll be fine. if you pass a cop and your car is smoking like a house fire, you may have an issue.
Old Mar 24, 2006 | 06:56 AM
NoVALude's Avatar
Default Re: Driving with oil leak? (syntax420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">as long as you top it off before you start and its not gushing out, youll be fine. if you pass a cop and your car is smoking like a house fire, you may have an issue.</TD></TR></TABLE>
It does not gush out but it is pretty bad.....yeah I am having a friend follow me just in case...hope the cops are not on the road when I make the trip
Old Mar 24, 2006 | 07:29 AM
JDMF22B's Avatar
Mechanically you will be fine. If you do get pulled over (its DC, i doubt you will), just explain your on your way to your mechanic to get it worked on. They shouldn't blink twice, and just to get it fixed. Worst case scenario you'll get a fix it ticket (if they even do those in DC), and when you go to the CHP station after you fixed it, they'll just write it off. Either way, no biggy
Old Mar 24, 2006 | 07:47 AM
NoVALude's Avatar
Default Re: Driving with oil leak? (JDMF22B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMF22B &raquo;</TD></TR><TR><TD CLASS="quote">Mechanically you will be fine. If you do get pulled over (its DC, i doubt you will), just explain your on your way to your mechanic to get it worked on. They shouldn't blink twice, and just to get it fixed. Worst case scenario you'll get a fix it ticket (if they even do those in DC), and when you go to the CHP station after you fixed it, they'll just write it off. Either way, no biggy</TD></TR></TABLE>
It will be like real early Sunday morning, so hopefully no bacon will be on the road
Old Mar 24, 2006 | 08:00 AM
AnthonyG2003
Guest
Posts: n/a
My 93 has been leaking oil like that for the past 5months, I work at valvoline and just keep getting it topped off. I have to do it that way until I can afford the h22 swap. And yes, Smoke comes from my hood, all it is...is oil dripping on hot parts of your engine/exhaust. Anyone know where it might be coming from? Its on the drivers side, and its from the back side of the engine....
Old Mar 24, 2006 | 08:35 AM
Jeffrey9's Avatar
Default Re: Driving with oil leak? (AnthonyG2003)
I have the exact same problem with an oil leak falling onto my header. But I can't locate the leak. Any input would be awesome.
Old Mar 24, 2006 | 08:44 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: Driving with oil leak? (Jeffrey9)
Yeah, I would love to know where mine is coming from...
Old Mar 24, 2006 | 08:56 AM
syntax.'s Avatar
in all the above cases it is probably:
1 - oil pressure sending unit
2 - o-ring behind the oil cooler inlet where the filter screws on
Old Mar 24, 2006 | 09:01 AM
93h22a1vtec's Avatar
#2 is common on 5th gens...but im assuming same goes for 4th however usually if that ring is bad you know, cause all ur oil will come out at once...(theres alot of pressure there)
Old Mar 24, 2006 | 09:04 AM
LUDER INTRUDER's Avatar
<U>2 - o-ring behind the oil cooler inlet where the filter screws on </U>
I had the same problem, I have a h22a and it was burning oil like crazy. It was pretty sad, I'll drive in the rain and the smoke was horrible. I just looked around and I found the leak. Just like he said behind the oil cooler. Just check it out it might be the same thing.
Old Mar 24, 2006 | 09:20 AM
NoVALude's Avatar
Default Re: Driving with oil leak? (LUDER INTRUDER)
When I pull the engine, I will tear down and take pics....I am pretty sure the leak is coming from the side of the engine where the balance shfts are.
I am not sure if the dude I got the car from ever had the bal. shaft retainer put in (the Honda recall). If the leak is not there then it is in the back and I will dig around to see.
Old Mar 24, 2006 | 10:46 AM
JDMF22B's Avatar
most common oil leaks on ludes, are improperly installed engines, and o-rings =p
Old Mar 24, 2006 | 11:18 AM
The_Sober's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoVALude &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure if the dude I got the car from ever had the bal. shaft retainer put in (the Honda recall). If the leak is not there then it is in the back and I will dig around to see.</TD></TR></TABLE>
my balance shaft seal went out on my last month. I don't think that's your problem, though. When mine went, my car lost 3qts of oil in less than a couple of minutes.
Old Mar 24, 2006 | 11:21 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: Driving with oil leak? (The_Sober)
I use about 1 - 1.5 a week....LOL I'm glad Valvoline has a free fluid refill service! haha......cant wait for a H22
Old Mar 24, 2006 | 11:39 AM
LudeyKrus's Avatar
Don't with it leaking oil if it is getting anywhere near the header.
Just a few months ago my buddy had his JRSC'd Miata's engine bay go up in flames from a small oil leak that got onto his header.
That being said, I drove around for about 2 weeks in my MR2 w/ the valve cover gasket sucked in and leaking over a quart a day down onto the exhaust, and made it out in one piece. YMMV.
Old Mar 24, 2006 | 11:52 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (LudeyKrus)
Mine isnt leaking on the header...Mine is in the back on the drivers side. I know it is hitting something hot though and it does smoke a little and smell of burnt oil. But I am trying to save a prelude from the junk yard so.....imma stick with her till I cant anymore!
Old Mar 24, 2006 | 05:40 PM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Don't with it leaking oil if it is getting anywhere near the header. </TD></TR></TABLE>
Pretty sure it is either on the right or in the rear....but thanks!
Old Mar 24, 2006 | 07:13 PM
integra pride's Avatar
Default Re: (NoVALude)
i m leaking on the rear main seal, they told me they have to take out the tranny and labor itself its 450...
Frstyl838
Oct 20, 2007 08:05 AM
AntMan401
Aug 23, 2006 09:38 AM
redlude97
Jun 24, 2005 06:01 PM
itsJDMyo
10
Aug 26, 2004 12:16 PM
Kisses_89_HB
16
Nov 14, 2003 09:41 AM
