cel 7 (tps) after installing 70mm tb
Old Mar 23, 2006 | 11:18 PM
sa90eg's Avatar
Default cel 7 (tps) after installing 70mm tb
will after we installed a 70mm tb the car throws a cel 7 (tps)
but when the motor is running a stock tb there is no cel car runs fine. with the 70 mm tb code 7 comes on and the motor seems to miss fire and bog ,the motor is on hondata s200. i just wanted to knoe if any racers on h-t came across this problem befor?
Old Mar 23, 2006 | 11:27 PM
EF-EF's Avatar
you gotta recalibrate your tps..I forgot the voltage to test so you might want to search..
Old Mar 23, 2006 | 11:42 PM
STREETWERKZ's Avatar
Default Re: (EF-EF)
typical misaligned TPS sensor.
your code, and the symptoms.
asianeric
Sep 11, 2009 09:35 AM
Rayog21
Aug 26, 2009 08:31 AM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
