maintenence help
hey people my maintenence required has been flashing and it would flash and go away and i didnt do anything about it but now its just completely on all the time what are some things i should check like fluids or what thanks for the posts
Under your dash to the right of the steering column there is a button. Turn the key on and hold the botton down for a few seconds and it should reset it. it doesn't know what shape your oil is in or anything like that it just flips on after so many miles of being reset.
Yeah, seems like someone asks this same question every two weeks, because nobody does a search and nobody looks in the owner's manual. For example...
https://honda-tech.com/zerothread?id=1535460
https://honda-tech.com/zerothread?id=1523960
It goes on at the oil change mileage intervals. But if you want to know what services to do and how often, look in the recommended maintenance schedule. You'll find it in the owner's manual as well as the service manual. If you don't have those manuals, you can get them here.
ITR1071
Dec 18, 2002 10:52 AM
