Buying Camber kit...Ingalls or Progress??
Okay...obviously the Ingalls kit is better because it's more expensive. But the Progress kits are selling for like $30 just for the rear! The only difference I can see is that the Ingalls kits are easier to adjust. Is it a bad idea to get a Progress camber kit?
the progress rear camber kit consists of only washers and a higher grade bolt. you can make your own for less than $30 easily. do a search.
I used a progress camber kit on my civic for the front and back and only got these stupid longer bolts and washers for the back. It didn't work for my civic with a 2.25" drop so I went with a ingalls camber kit for the back. Much better. I have ingalls front and rear on my integra and they are a lot better. If you're going to do it, do it right. It also depends on how much of a drop you have and your degrees off?
