screaming alternator
my alternator screams until i rev up the engine then it goes away for awhaile. i hear a bad ground will cause this. where are the engine ground wires. i have a h22 swap in 94 accord. my belt is tight. also i doesnt make any noise if i disconnect the green plug and the 12-volt wire from the alternator. thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94h22 »</TD></TR><TR><TD CLASS="quote">my alternator screams until i rev up the engine then it goes away for awhaile. i hear a bad ground will cause this. where are the engine ground wires. i have a h22 swap in 94 accord. my belt is tight. also i doesnt make any noise if i disconnect the green plug and the 12-volt wire from the alternator. thanks for any help</TD></TR></TABLE>sounds like the belt.. like the guy above me said
2point2
Mar 29, 2005 11:11 AM
mjrage
Jul 4, 2004 01:06 AM
