Arch Vs Mig
Old Mar 23, 2006 | 05:36 PM
C_H_A_D's Avatar
Default Arc Vs Mig
Ok boys How much stronger is a stick weld over a mig weld. the reason I ask is I do a lot of big steel work. I always stick weld (i use a 106 rod its similar to a 7018)
well my buddy was looking at some miller generators that will push an arc or a mig. Well I dont think that a mig weld would be strong enough. Yes it would be a lot faster and easier. I do a lot of overhead and vertical up's. I just wanted some opinions.
Modified by NINJASWORD at 10:40 PM 3/23/2006
Old Mar 23, 2006 | 06:21 PM
dfoxengr's Avatar
Default Re: Arch Vs Mig (NINJASWORD)
theyre really different processes. i wouldnt compare the two.
and its just arc...no h
Old Mar 23, 2006 | 06:39 PM
C_H_A_D's Avatar
Default Re: Arch Vs Mig (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">theyre really different processes. i wouldnt compare the two.
and its just arc...no h</TD></TR></TABLE>
I know its a different process, I know how to mig weld steel. The question is are they equal in strength?
Old Mar 23, 2006 | 08:06 PM
stealth-wrx's Avatar
Arc is the strongest out of all of them. All structural people will say the same. It provides proper penetration and shielding. Any building structure, pressure tube, or fluid transfer tube in your entire city was arc welded. On building structures they require something like 7 full passes.
Old Mar 23, 2006 | 08:12 PM
k24em2's Avatar
Default Re: Arch Vs Mig (stealth-wrx)
Arc welding encompasses a ton of different processes. GTAW, SMAW, GMAW, SAW, FCAW, etc etc.
GMAW vs SMAW is two different processes, used for two different things.
Old Mar 25, 2006 | 02:05 AM
SIRX's Avatar
Default Re: Arc Vs Mig (NINJASWORD)
most of the steel beams we build at work we mig with flux core. When I had to get state certified for structure steel welding We had to MIG and do vertical up's
Tigfab
Welding / Fabrication
Mar 24, 2007 07:42 AM
TEGNO1
16
Jan 18, 2007 02:18 AM
SEFIxCivic
Mar 10, 2006 07:36 PM
timntam
Oct 20, 2005 08:17 AM
