clutch Problem?
Old Mar 23, 2006 | 02:49 PM
ADRIAN99SI's Avatar
Default clutch Problem?
i just finsh installing a new act maxx pp, flywheel and 4 puck.
i feel the clutch pedal vibrating like the motor i did a quick search and couldn't find much. can someone help?
thanks
Old Mar 23, 2006 | 06:29 PM
96b18c's Avatar
Default Re: clutch Problem? (ADRIAN99SI)
Same thing happened to me, turned out I was missing a bolt on my pressure plate, which wouldn't allow me to apply torque evenly throughout the pressure plate. If it isn't too bad, then it is probably just chatter.
Old Mar 24, 2006 | 01:33 PM
ADRIAN99SI's Avatar
Default Re: clutch Problem? (96b18c)
the vibration is only when i press slightly on it and when i start to feel pressure from the pressure plate it goes away when i let go of the clutch it starts to vibrate again im trying to explain it the best way i can thanks for all the help guys.
I still have not adjusted clutch pedal yet can be that?
Vinde
Transmission & Drivetrain
Oct 30, 2014 08:14 AM
TrojanMan01
Sep 21, 2005 10:07 AM
I Quarantined I
Aug 16, 2005 08:38 AM
-[95cxhatch]-
Mar 1, 2004 01:22 PM
