installing jdm fenders got a question
Old Mar 23, 2006 | 01:10 PM
M2B4's Avatar
Default installing jdm fenders got a question
okay im wiring the fenders into the turning light (far outside one) the fender has black and 2 green/yellow wires the turning light has black and a red/green wires. can i connect the 2 green/yellow together and attach those to the red/green then just connect the 2 blacks? also can i use 194 bulbs in the fender socket?
Old Mar 23, 2006 | 01:34 PM
M2B4's Avatar
Default Re: installing jdm fenders got a question (M2B4)
any one i need a answer rather quick?
Old Mar 23, 2006 | 03:24 PM
M2B4's Avatar
any one?
i wired it like i previous said and its not working so i ran power wire directly to battery to check my ground and it worked. so i checked the red/green wire with volt meter and im getting a -00.0 instead of the regular 00.0 any one know why?
Old Mar 23, 2006 | 06:14 PM
Don Jefe's Avatar
Default Re: (M2B4)
Uhm, i dunno about anyone else, but im a lil confused, wiring fenders?
Do you mean sidemarker on the bumper?
Old Mar 23, 2006 | 07:10 PM
M2B4's Avatar
Default Re: (Hank the retard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hank the retard &raquo;</TD></TR><TR><TD CLASS="quote">Uhm, i dunno about anyone else, but im a lil confused, wiring fenders?
wiring the sidemarker on the jdm fenders....
Old Mar 24, 2006 | 03:08 AM
hp92lude's Avatar
Default Re: (M2B4)
im pretty sure thats how i wired mine. just took the 2 same colored wires on the sidemarker and wired them together then matched them to the wires that control the outside turnsignal light. make sure you got the right ground cause i think there were like 2 or 3 and they all had different silver spots on them when i did it.
Old Mar 24, 2006 | 09:39 AM
M2B4's Avatar
Default Re: (hp92lude)
mine only has (car side) 1 ground the black and then the red/green power wire. the (fender side) has the 2 green/yellow and black. i hooked the blacks together and then connected the reg/green and green/yellow didnt work so i ran the green/yellow to the battery alone it worked so my ground is good but im not pulling power to my turn light. i have the jdm lights so that one (outer turn light)was never used b/c they dont have a hole for the light so i dont know if it worker earlier. the fuse must be fine b/c every other turn signal works. any one know what is could be why that 1 wire isnt getting power?
PS. when i use volt meter on the power wire is says -00.0 instead of the normal 00.0 display when theres no current.
Old Mar 24, 2006 | 10:05 AM
VtecFreePrelude's Avatar
the volt meter doesn't make a difference at 0 so you can forget about that.
the light may need a relay to work correctly or you could have the wrong power wire. or you may need to use two wires to power it enough.
i'm just guessing so don't take any of this as experience
Old Mar 24, 2006 | 01:12 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (VtecFreePrelude)
post pix and i can help
Old Mar 24, 2006 | 01:29 PM
M2B4's Avatar
Default Re: (AnthonyG2003)
Dont know if this will help but im on lunch and only got a few mins cant get real pix. i just cut the socket off of the lights circled and wired off them. and connected the 2 green/yellows together. the socket for the light has a black and reg/green wires
**pic from google; not my car**
Old Mar 24, 2006 | 01:35 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (M2B4)
ur bumper lights at the bottom should only have 2 wires. You connect the 2 hot wires out of your side marker to the hot off the bumper lights. Then the ground wires you do the same thing with, connect them to the ground. Its hard for me with out pix. You arent connecting the wires to the socket, you need to splice them together.
Old Mar 24, 2006 | 08:15 PM
hondamanmark's Avatar
"Y" off of those turn lights neg to neg and pos to pos....done
Old Mar 24, 2006 | 08:19 PM
Shakes's Avatar
space cadet
Default Re: (hondamanmark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanmark &raquo;</TD></TR><TR><TD CLASS="quote">"Y" off of those turn lights neg to neg and pos to pos....done</TD></TR></TABLE>
That would make the side markers either always on.
Old Mar 24, 2006 | 10:07 PM
M2B4's Avatar
Default Re: (Shakes)
...i know how to do wiring my question was why am i pulling a -00.0 on the voltmeter why isnt the red power wire on the back of the turning lights pulling any power? i need ideas b/c ive used all mine. fyi fuses are fine and all other turning lights work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">You arent connecting the wires to the socket, you need to splice them together.</TD></TR></TABLE>
i know that lol.
Old Mar 26, 2006 | 04:05 PM
M2B4's Avatar
Default Re: (M2B4)
bump
Old Apr 26, 2006 | 09:17 AM
M2B4's Avatar
Default Re: (M2B4)
**UPDATE** i installed me new amber parking lights today and noticed there were 3 plugs down there. the 2 for the parking lights/turn signals and there was an extra. the extra one was what i cut into and couldnt get any power. my question now is did all ludes come pre wired for fogs? thats the only thing i can think that 3rd plug is for. any one know?
Old Apr 26, 2006 | 09:32 AM
SteveoBA8's Avatar
Default Re: (M2B4)
Yep that extra plug is most likely for the fogs. Mine has it also.
Moto DC2
Lighting
Dec 19, 2007 07:37 AM
oranginal
May 24, 2006 12:47 PM
bodazappa
Jun 13, 2004 03:12 PM
B18C GSR CIVIC
Apr 19, 2004 09:47 PM
