sqeaking noise while releasing clutch.
There's a sqeaky noise coming from my engine area everytime I release my clutch slowly and engage'n into either first gear or reverse. It only happens when I am slowly release the clutch while engage'n in first gear or using the clutch to reverse slowly. No other gear have a problem. Whwat is wrong wtih my car?
if you look at the tranny and see the lil rubber boot that covers the bellcrank next to the slave cylinder there is a cut or slice molded into the boot, inside the boot slave cylinder pushes the bellcrank,the slave has a ball shaped end that needs to be greased lightly or you can use spray lubes for a quik fix but dont spray into the clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy »</TD></TR><TR><TD CLASS="quote">nothing is wrong. just turn the music up</TD></TR></TABLE>
I have no idea where exactly the nosie is coming from. But it is annoying! I guess i'll just put up with it untill i get use to it. thanks for the replies though
b20beast83
Transmission & Drivetrain
Sep 4, 2008 08:43 PM
wilntegra
May 3, 2005 04:22 PM
