No heat in the cabin...
Old Mar 23, 2006 | 11:04 AM
popo bawa's Avatar
Default No heat in the cabin...
Hi guys. My blowers are just blowing cold air!
My engines running at normal temp and the raditor hoses are getting hot.
I've felt the hoses that lead into the bulkhead and both of them are warm too.
Any ideas why it ain't blowing warm air?
Oh its a 92 4gen JDM lude.
Thanks
Mark
Old Mar 23, 2006 | 11:19 AM
skunked's Avatar
Default Re: No heat in the cabin... (popo bawa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popo bawa &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys. My blowers are just blowing cold air!
Thanks
Mark</TD></TR></TABLE>
Sounds like the valve is not openeing to let the hot coolant pass though the heater core.
Old Mar 23, 2006 | 11:24 AM
popo bawa's Avatar
Default Re: No heat in the cabin... (skunked)
Once the hot water passes into the bulkhead I'm guessing it can only go into the heater core (heater matrix?) Or can it bypass this?
Both pipes that lead to/from the bulkhead are hot so this suggests water is flowing in and out okay...
Old Mar 23, 2006 | 11:28 AM
skunked's Avatar
check the valve, try opening and closing the valve manually then see if you get heat. I was working on a civic the other day and it had the same problem which ended up being the valve.
Old Mar 23, 2006 | 11:33 AM
popo bawa's Avatar
sound like a total n00b now- wheres this valve situated?
Thanks for the help by the way!
Old Mar 23, 2006 | 11:50 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popo bawa &raquo;</TD></TR><TR><TD CLASS="quote">sound like a total n00b now- wheres this valve situated?
Thanks for the help by the way!</TD></TR></TABLE>
On the civics and tegs its on the heater core hose near the firewall. I would to assume it's in the same spot on the preludes.
Old Mar 23, 2006 | 12:09 PM
popo bawa's Avatar
Any chance of description of the valve please mate?
How do I check it manually?
As you may be able to tell I've not got much experince with the cooling system!
Old Mar 23, 2006 | 12:13 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popo bawa &raquo;</TD></TR><TR><TD CLASS="quote">Any chance of description of the valve please mate?
As you may be able to tell I've not got much experince with the cooling system!</TD></TR></TABLE>
I can't find a diagram or pic, but it should be an in-line valve with a cable that runs from the valve to the temp control unit on your dash.
Modified by skunked at 1:29 PM 3/23/2006
Old Mar 23, 2006 | 12:38 PM
popo bawa's Avatar
Okay, thats cool- I'll let you know how I get on.
Thanks for your help- much appreciated!
JeeK
Honda Civic (2001 - 2005)
Dec 21, 2014 08:03 AM
cloven
Feb 18, 2006 07:06 PM
Hondaciv95VX
20
Dec 5, 2005 01:41 PM
cascaritas
17
Sep 22, 2004 06:50 PM
