Header for my set up?
Old Apr 2, 2002 | 06:05 PM
xxplosif1's Avatar
Default Header for my set up?
I have a 1992 Integra RS
I have intake, exhaust and an NX nitrous kit 50-75 hp.
-What header should i get if i'm getting crower cam 404s?
-Of course i'll be spraying nitrous
-CC or SS (heard the CC would craked with the nitrous?)
-is the 2.5" collector is worth it in my case or just a waste?
-Finnaly....4-1 OR 4-2-1 for my B18A set up?
thanks
Old Apr 2, 2002 | 07:54 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: Header for my set up? (xxplosif1)
I would suggest a 4-1 SS set up since the 4-1 is for more drag orientated since its more free flowing and stainless steel since metal can withstand more heat and would not crack.
Old Apr 2, 2002 | 09:15 PM
Leimokei's Avatar
New User
header for your setup...retard the timing on your exhaust cam...you have low end torque, what i recommend is getting a 4-1 header with a 2.5in collector and high flow cat...that way you have no bottle neck in your setup...everything work in conjunction not just one piece at a time...
side note: I had cams and was squeezing nitrous...highly getting the car tuned...or get hondata stage 2
Old Apr 3, 2002 | 05:10 AM
xxplosif1's Avatar
Default Re: Header for my set up? (Leimokei)
ya i'll have cam gears toom to tune the cams. Crower did recommend me to get the 404s for my B18A since i was using nitrous. he said that i'll be fine with these.
what kind of cams you used to have?
Old Apr 3, 2002 | 02:43 PM
xxplosif1's Avatar
ttt
Old Apr 3, 2002 | 03:06 PM
Leimokei's Avatar
New User
i had crower cams previously, now i'm running stock cams...with a higher shot of nitrous.....
Old Apr 4, 2002 | 07:15 PM
SCsol's Avatar
what power range is 4-2-1 headers for?
what power range is 4-1 headers for?
Old Apr 5, 2002 | 07:58 AM
vtecteg's Avatar
Default Re: Header for my set up? (lowsol)
4-1=high end power
4-2-1=low end power
Old Apr 5, 2002 | 09:03 AM
xxplosif1's Avatar
Default Re: Header for my set up? (vtecteg)
Ok....4-2-1 for keeping my nice mid range torque....and my cams will take care of the top end power. Sounds good?
Or should i concentrate everything on the high end with the 4-1 header.....with a 6800 rpm redline?
[Modified by xxplosif1, 6:03 PM 4/5/2002]
Old Apr 5, 2002 | 09:28 AM
lazyguy's Avatar
go with the jdm itr 4-1 header its a great header and would work good for ur setup
i actually have one im selling email me if ur interested
Rocket
13
Apr 29, 2005 09:00 AM
D16Jon
21
Sep 29, 2003 12:12 PM
ONE SLOW EG
Apr 2, 2003 05:52 PM
Pharcyde
Dec 15, 2002 04:55 PM
2fastGSR
Oct 2, 2001 12:53 PM
