Motor/tranny mounts
Old Mar 23, 2006 | 06:18 AM
Jamied's Avatar
Default Motor/tranny mounts
i have a 2000 civic si
okay guys i am looking for some reliable good mounts for my motor and tranny.
i was looking at the Hasport motor mounts. there are 3 correct for my car? and how many tranny mounts?
i dont want any vibration with the mounts. so what do u all suggest? i am feeling a lot of play with the OEM mounts i now. i think there bad.
any help please?
Old Mar 23, 2006 | 07:35 AM
Jamied's Avatar
anyone?
Old Mar 23, 2006 | 07:41 AM
Luserkid's Avatar
Default Re: (Jamied)
Hasport will give you a little bit of vibration but nothing you could look past. If you still have your torque mounts and dont want so much vibration get the Inserts. A little stiffer and less vibration.
Old Mar 23, 2006 | 07:43 AM
Jamied's Avatar
what do u mean by torque mounts?
i have whatever is stock in my car. i dont want any vibration. so what inserts should i get for the motor and tranny? and how many mounts are there for the tranny?
Old Mar 23, 2006 | 08:44 AM
pgpunkguy's Avatar
there are two upper mounts (driver and passenger sides)
there are two lower torque mounts (driver and passenger sides)
there is (sometimes) one tranny mount in the back towards the firewall
if your mounts are going bad, you can temporary prolong their life by using urethane inserts, but it'll give you lots of vibration.
you can get aftermarket mounts, but they'll be stiff too since they usually have urethane bushings.
other option is to go oem... or find some at a local salvage yard.
Old Mar 23, 2006 | 08:49 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (pgpunkguy)
Those bottom torque mounts pretty much disentegrate after some time. Urethane inserts help, but if you choose to go that route, make sure the OEM rubber is still good. I just had to by a new driver side torque mount because it pretty much fell apart
Old Mar 23, 2006 | 08:56 AM
EE_Chris's Avatar
If you want NO vibration, then you want OEM...period.
Going with an urethane insert will work - but there will be vibration. HASport mounts will work better - but they'll probably have more vibration than the inserts. Inserts are really cheap, so you might find yourself dealing with a little vibration for the money you'll save from not going one of the other routes. Between Prothane and Energy Suspension, they've got inserts for all of the locations in the engine bay.
Old Mar 23, 2006 | 09:18 AM
Jamied's Avatar
now i have heard HASport makes two different kinds of mounts? one is race and one is street or something?
im most likely going to go with OEM
Old Mar 23, 2006 | 10:07 AM
Jamied's Avatar
bump
Old Mar 23, 2006 | 10:10 AM
strokedb16delsol's Avatar
inlinefour.com has hardened stock mounts made by spoonsports and they will not give you a vibration like all the other pos motor mounts out there
Old Mar 29, 2006 | 06:31 PM
dave1234's Avatar
Default Re: Motor/tranny mounts (Jamied)
I heard Arizona Race and Machine makes nice cheap mounts. Never used myself but look identical to Hasport's.
h22civicek
Feb 18, 2009 11:06 AM
SPOOLINmatt
May 30, 2007 06:03 PM
spooledhonda
Jan 1, 2007 07:35 AM
Tire Monkey
May 2, 2004 05:23 PM
rondigs
Jul 21, 2003 06:26 PM
