removing rear caliper on 92 Si hatch
Old Mar 23, 2006 | 04:51 AM
CRXified's Avatar
Default removing rear caliper on 92 Si hatch
ok im not sure if somebody before me rounded the bolts or not for the caliper mounting bolts, or i cant figure out teh size.
i thought it was a 14mm, but it seems they are a bit smaller than 14 and a bit bigger than 13mm. im guessing somebody rounded them off before, but i just wanted to ask to see if anybody knew the size for sure.
its the 2 bolts that hold the caliper to the mounting plate
TIA
Old Mar 23, 2006 | 05:44 AM
AutoXer's Avatar
Default Re: removing rear caliper on 92 Si hatch (CRXified)
I'm pretty sure it's 14. Most stuff on the suspension is 14, 17 or 19mm.
Old Mar 23, 2006 | 05:47 AM
fmrprojects's Avatar
Default Re: removing rear caliper on 92 Si hatch (AutoXer)
if its the 2 bolts that hold the caliper on the bracket, the it should be a 12mm
Old Mar 23, 2006 | 05:51 AM
AutoXer's Avatar
Default Re: removing rear caliper on 92 Si hatch (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">if its the 2 bolts that hold the caliper on the bracket, the it should be a 12mm</TD></TR></TABLE>
I think you may be right; I was thinking of something else.
Old Mar 23, 2006 | 08:50 AM
CRXified's Avatar
it is those 2 bolts, but i cant see that must rust being built up on them to make them 2 sizes too big... i think they are 14mm or WERE 14 but are rounded off...
BUT i could be wrong, it might be 12. any other confirmations?
Old Mar 24, 2006 | 06:16 AM
CRXified's Avatar
bump for more help
Old Mar 24, 2006 | 06:54 AM
pdiggitydogg's Avatar
I was going to say maybe they were replaced and are standard...but youre in Canada...so thats unlikely.
Old Mar 24, 2006 | 08:36 AM
penguinman717's Avatar
uhh i think they should be 14mm. mine are so yeah
Old Mar 25, 2006 | 03:16 PM
CRXified's Avatar
ya they are probabl rounded off 14mm, ill have to find a way to get them off otmorrow, thanks guys
Old Mar 25, 2006 | 04:41 PM
spoonracer84eg's Avatar
Default Re: (CRXified)
i would guess 14mm since they are under some stress.
Old Mar 27, 2006 | 02:46 PM
CRXified's Avatar
they were 14mm, ket word WERE lol
had to hammer a standard socket onto it and then use impact wrench after heating it to get them off.
does anybody know what the caliper # for the 92-95 Si civics are? is it 7H3 on the bracket?
Old Mar 27, 2006 | 02:54 PM
aown61's Avatar
they are 14mm just recently changed my discs.
TorquelessB16A2
Aug 14, 2008 02:14 PM
vacantskies88
Oct 25, 2007 06:16 PM
richboi
11
Aug 14, 2007 04:23 AM
huge230
14
May 17, 2007 11:16 AM
CooBlueDAB
Apr 16, 2007 08:50 PM
